bruceg
April 7, 2021, 2:31pm
1
I have created a simple config with just a handful of VIFs, no routing protocols with a static default gateway. From the CLI I can ping/connect to devices on the internet. If I am connect through a VIF (laptop connected to a switch port in the 802.1q VLAN) I can only ping the default gateway but can not go any further. Same thing happens if I try ti ping from the CLI using the VIF IP address as the source address - the packets die.
Is there something I need to turn on? Has something changed that I’m not aware of on this version?
Just from what you said, I don’t understand what your problem and configuration are, sorry!
bruceg
April 7, 2021, 2:37pm
3
I’ll copy the config later when I get back to the office and then post it here
bruceg
April 7, 2021, 3:19pm
5
Below is a snip from my config. From the command line I can ping the world. Here are the results of my pings:
vyos@sb-02:~$ ping 8.8.8.8
PING 8.8.8.8 (8.8.8.8) 56(84) bytes of data.
64 bytes from 8.8.8.8: icmp_seq=1 ttl=115 time=15.5 ms
64 bytes from 8.8.8.8: icmp_seq=2 ttl=115 time=18.0 ms
64 bytes from 8.8.8.8: icmp_seq=3 ttl=115 time=20.1 ms
^C
— 8.8.8.8 ping statistics —
3 packets transmitted, 3 received, 0% packet loss, time 5ms
rtt min/avg/max/mdev = 15.531/17.866/20.051/1.854 ms
vyos@sb-02:~$ ping 8.8.8.8 interface 10.25.242.1
PING 8.8.8.8 (8.8.8.8) from 10.25.242.1 : 56(84) bytes of data.
^C
3 packets transmitted, 0 received, 100% packet loss, time 29ms
vyos@vyos# show
hw-id 18:66:da:06:57:33
description “trunk to 3750x-01”
duplex auto
hw-id a0:36:9f:02:63:30
speed auto
vif 240 {
address 10.25.240.1/24
description MANAGEMENT
vif 241 {
address 10.25.241.1/24
description “safebound lan”
vif 242 {
address 10.25.242.1/24
description “priceline lan”
vif 243 {
address 10.25.243.1/24
description cameras
ethernet eth2 {
hw-id a0:36:9f:02:63:31
ethernet eth3 {
hw-id a0:36:9f:02:63:32
ethernet eth4 {
address 173.9.181.225/29
hw-id a0:36:9f:02:63:33
loopback lo {
protocols {
static {
route 0.0.0.0/0 {
next-hop 173.9.181.230 {
service {
dhcp-server {
shared-network-name cameras {
authoritative
subnet 10.25.243.0/24 {
default-router 10.25.243.1
dns-server 8.8.8.8
lease 86400
ntp-server 108.59.2.24
range CAMERA-RANGE {
start 10.25.243.33
stop 10.25.243.254
shared-network-name mgmt {
authoritative
subnet 10.25.240.0/24 {
default-router 10.25.240.1
dns-server 8.8.8.8
lease 86400
range MGMT-RANGE {
start 10.25.240.129
stop 10.25.240.254
shared-network-name priceline-lan {
authoritative
subnet 10.25.242.0/24 {
default-router 10.25.242.1
dns-server 8.8.8.8
lease 86400
range PRICELINE-RANGE {
start 10.25.242.33
stop 10.25.242.254
shared-network-name safebound-lan {
authoritative
subnet 10.25.241.0/24 {
default-router 10.25.241.1
dns-server 8.8.8.8
lease 86400
range SAFEBOUND-RANGE {
start 10.25.241.33
stop 10.25.241.254
ssh {
listen-address 10.25.240.1
listen-address 10.25.241.1
listen-address 10.25.242.1
listen-address 10.25.243.1
listen-address 10.25.244.1
listen-address 173.9.181.225
system {
config-management {
commit-revisions 100
console {
Are you a one-armed route?
bruceg
April 7, 2021, 3:24pm
7
No - you’ll notice that there a 5 interfaces. eth1 is the trunk and eth4 is the outside interface
You have not configured a bridge or IP, how do you bridge the remaining 4 ports? How to route?
bruceg
April 7, 2021, 3:35pm
9
A bridge? I would think it wouldn’t need a bridge. I never had to do that with 1.1.8
Well, I misread it. It seems to work, because IP has been configured
Any questions now?
bruceg
April 7, 2021, 3:44pm
11
Not sure what you mean??? The config I posted above does not route from any of the networks on the VIF interfaces.
Hey, let’s see, if there are no configuration errors from the configuration, I suggest directly Ping the specific device and check that everything is OK for each device routing table, sorry
I don’t see any obvious errors in this configuration.
bruceg
April 7, 2021, 3:55pm
13
My post above with the config also shows the ping attempts
Just a suggestion: try routing trace on a real device from any VLAN 241 network
I did not find any errors in this configuration file. you can only check it level by level. If necessary, you can capture the traffic packet
Sorry again, based on configuration, I may not be able to help you
bruceg
April 7, 2021, 4:11pm
15
I have done that with the same result.
c-po
April 7, 2021, 4:13pm
16
I see no NAT configuration above, that is why there is no connection from your LAN to WAN.
I can’t believe I didn’t think of NAT. Maybe that’s the answer.
bruceg
April 7, 2021, 4:36pm
18
Well Jack, I can’t believe it either )) Thanks for the help and you too c-po
