(Sorry for my bad english)
I have an installed vyos 1.0.4 with dual WAN (load balance/failover) and single LAN.
I need a port forward from the two WAN interface to a server in the LAN.
(same port to same ip)
Info: if i set a port forward to 1 wan - 1 lan interface, its working well, but the dual forwarding
working only randomly.
So, i try that, and working well, but i have anothet problem…
when i used vyos 1.0.3, the load-balance worked well, but in the 1.0.4 version the balancer randomly changed the client (wan)gw. I test my (wan) IP, and randomly get back the wan1/wan2 ip address. wtf??? I need a sticky connection to route my clients out “static wan gw” such us client1=> wan1 / client2 => wan2. Of course if any wan connection lost, change the default gw all of clients. (wan failover working well yet!)
