If an interface has got a fixed address (set interfaces ethernet eth1 address ‘192.168.0.1/24’) and some time later one would like to change it to dhcp (set interfaces ethernet eth0 address dhcp) then the user gets:
Can’t configure static IPv4 address and DHCP on the same interface.
Of course, that’s true.
Why does VyOS not automatically remove the static IP-Address (or asks for it or give some hint how to remove the static addess)?
There are MANY other cases of mutually incompatible configuration settings. A design assumption in the UI is that the operator has read the documentation, including
Thanks for your answer!, I’ve read the manual, but the delete-command has no example - it’s just mentioned as a note:
and therefore I probably did not “internalized” it.
Yes - and many of them are probably already checked on commit…
and I assume, that many of the checks know the solution but just explain what’s wrong - and not how to solve it.
It was just an idea.
Thanks a lot for your help with the delete-command!,
kind regards,
Tom
