I had previously been using the AWS VyOS image 1.1.0 (upgraded to 1.1.8) but I have recently been testing the paid version on AWS of 1.1.8 as well.
I’m using it for site-to-site VPNs.
My problem is that as soon as I configure a peer I lose connection to the instance and need to reboot it. When it comes back up the last commit with the peer info is not there anymore. If I attempt to create the first peer again same thing.
I have used the other image quite a bit and never had any problem like this.
Is there something I need to do first?
Basically my steps are:
- create default IKE and ESP groups
- set ipsec interface eth0
- commit - all ok
- create first peer
- commit - lose connection
I’ve also tried updating to the latest nightly build and it seems ok.
Thanks
