I have a virtual environment with 5 subnets. I configure the vyos with 5 interfaces
192.168.101.14/28
192.168.102.14/28
192.168.103.14/28
192.168.104.14/28
192.168.105.14/28
how do I configure vyos to route between networks? I added a static route
set protocols static route 192.168.102.0/28 next-hop 192.168.102.14
set protocols static route 192.168.101.0/28 next-hop 192.168.101.14
and setup a host (192.168.101.89) and (192.168.102.89) but cannot ping each other. Is this even possible?
the attached interfaces will route to each other without any additional configuration.
in your test machines, set their gateway to the respective IP of the router.
192.168.101.89 would get 192.168.101.14 as its gateway
192.168.102.89 would get 192.168.102.14 as its gateway
I don’t understand fully… This is somewhat what im trying to do my self… I have 3 networks each with 2 vms I need to get to internet outside and how do I set them up I have used the same ips ? I need to set or get to router and then out to internet gateway which is 254.
