Hi together, I’m pretty new to BGP and vyos.
My BGP Setup is as follows:
set interfaces ethernet eth0 address '194.50.xx.xxx/24'
set interfaces ethernet eth1 address '2001:7f8:f2:xx:x:axxx:xxxx:1/64'
set protocols bgp 21xxxx address-family ipv6-unicast network 2a0e:b107:xx::/48
set protocols bgp 21xxxx neighbor 2001:7f8:f2:e1::xxxx:1 remote-as '20xxxx'
set protocols bgp 21xxxx neighbor 2001:7f8:f2:e1::xxxx:1 update-source '2001:7f8:f2:xx:x:axxx:xxxx:1/64'
set protocols static route6 2a0e:b107:xx::/48 blackhole distance '254'
This setup works as long as i do not try to use one of my announced IPs from my range 2a0e:b107:xx::/48 on a new interface like eth2.
set interfaces ethernet eth2 address '2a0e:b107:xx:1::1/64'
Right after setting this address BGP stopps working and trying to ping the neighbor 2001:7f8:f2:e1::xxxx:1 also fails. Traceroute shows that the route is now trying to go via the new eth2.
For first you use an incorrect update source address.
You need to declare update-source without netmask.
You should have gotten errors with your commit.
vyos@r1# commit
[ protocols bgp 65001 ]
% Invalid update-source, remove prefix length
Error configuring routing subsystem. See log for more detailed information
Can you use these (2001:DB8::/32 or /64) address space for providing configuration?
It is no clear what there
For example network range for 2001:db8:f2:aa:a:aaaa:aaaa:1/64
2001:0db8:00f2:00aa:0000:0000:0000:0000-
2001:0db8:00f2:00aa:ffff:ffff:ffff:ffff
Without full configuration and understanding IP scheme I can’t reproduce it.
vyos@r1:~$ show interfaces
eth0 - u/u
eth1 2001:db8:f2:aa:a:aaaa:aaaa:1/64 u/u
eth2 2a0e:b107:bb:1::1/64 u/u
vyos@r1:~$ show ipv6 bgp neighbors 2001:db8:f2:aa:a:aaaa:bbbb:1 advertised-routes
BGP table version is 1, local router ID is 1.1.1.1, vrf id 0
Default local pref 100, local AS 65001
Nexthop codes: @NNN nexthop's vrf id, < announce-nh-self
*> 2a0e:b107:bb::/48
:: 0 32768 i
