Since 1.1.0-beta1 has the newer kernel with fq_codel, I made a first attempt at adding a fq-codel queue type. It seems to work here.
Hello carl.byington
I think It is good idea to fork thorse repositories and request git pull request on github.
vyatta-op-qos
vyatta-op-qos/vyatta-show-queueing.pl at helium · vyos/vyatta-op-qos · GitHub
vyatta-cfg-qos
vyatta-cfg-qos/vyatta-qos.pl at helium · vyos/vyatta-cfg-qos · GitHub
vyatta-cfg-qos/FairQueue.pm at helium · vyos/vyatta-cfg-qos · GitHub
vyatta-cfg-qos/ShaperClass.pm at helium · vyos/vyatta-cfg-qos · GitHub
vyatta-cfg-qos/Shared.pm at helium · vyos/vyatta-cfg-qos · GitHub
vyatta-cfg-qos/templates/traffic-policy at helium · vyos/vyatta-cfg-qos · GitHub
Best regards.
Hiroyuki Sato.
I will eventually do that, but I want to make sure this is working first. An improved version is at 510 Software Group with the patch at http://www.five-ten-sg.com/util/vyos-fq-codel.patch
I still need to add some error checking, since
match tiny ip small
match tiny ip source address 1.2.3.4/0
should generate an error. “ip small” is incompatible with the other match types.
Hello carl.byington .
I introduced about your work in Japanese VyOS community.
I’ll let you know if someone test.
Best regards.
Hiroyuki Sato.
