The way you do the delete it leaves everything after the dhcpv6-options in the config and only deletes the 56 which is not what you want. You want the whole node removed.
@ginko regardless of available workarounds, anything with a traceback should is a bug. Could you please verify if this behavior persists in the latest rolling release? If it does, please file a report at https://vyos.dev and include the full configuration along with the steps to reproduce the issue.
Happy to report the earlier reported issue didn’t re-appear on the latest nightly. I was able to delete dhcpv6-options from my config:
Welcome to VyOS!
. VyOS 2026.04.13-0034-rolling
└ ──┘ current
* Documentation: https://docs.vyos.io/en/latest
* Project news: https://blog.vyos.io
* Bug reports: https://vyos.dev
You can change this banner using "set system login banner post-login" command.
VyOS is a free software distribution that includes multiple components,
you can check individual component licenses under /usr/share/doc/*/copyright
WARNING: This VyOS system is not a stable long-term support version and
is not intended for production use.
admin@server:~$ show configuration commands | match dhcpv6
set interfaces pppoe pppoe0 dhcpv6-options pd 0 length '56'
admin@server:~$ conf
admin@server# delete interfaces pppoe pppoe0 dhcpv6-options
admin@server# commit
admin@server#
