It seems that the ‘http://repo.saltstack.com/apt/debian/8/amd64/2017.7’ repository specified in the default config no longer exists.
How can I build iso without it?
Today, I faced same problem. You should change path as’http://archive.repo.saltstack.com/apt/debian/8/amd64/2017.7’ in defaults.json file. I guess it will fix your problem.
Hi @utosun, thanks. Merged Update debian saltstack http path with new one by ugurtosun · Pull Request #108 · vyos/vyos-build · GitHub
