windows vpn client has checkbox: “use default gateway on remote network” which sends all traffic over the vpn
after disabling it, look into powershell Add-VpnConnectionRoute command, to specify which routes to use after connect
I’m not using Windows, I’m using mac os, and I don’t have such an option.
I’m just curious to know if creating static routes is required to reach whatever subnets are on other interfaces such as eth1?
Note ppp IP address negotiation doesn’t hand out a subnet, so you will end up with classless route
If VPN interface is in 10.x range, you will end up with 10.0.0.0/8 route automatically
If VPN interface is in 172.16…31 range, you will end up with /16 route automatically
So by using proper addresses, you might get away without hassling with client routes
