Commit error - need help
Hi all
Seeing this error on a previously working config when I do a configure - conf - load - commit cycle
Means I have no firewall config loaded into the running config. Help needed. :slight_smile:
Running 2025.03.18-0018-rolling
[ firewall zone local member interface local-zone ]
Incorrect path /sys/class/net/local-zone: no such file or directory
Invalid value
[[firewall]] failed
Commit failed
[edit]```
I can share
Can you share the old firewall config that was working?
It turns out to be a simple fix, and I am not sure whether the migration scripts have perhaps missed something here.
Previous working config.boot had this interface assignment.
        member {
            interface "local-zone"
I amended this to the following, and all is working as expected.
        member {
            interface "lo"
