Communication between vlan and physical interface.
#1
I have lan physical interface, when have adres 192.168.5.1 and I have vlan-9 with adress 192.168.9…1 on the same physical interface.
How can I communication betwen vlan9 adress and physical interface adress ?
#2
directly connected interfaces will talked to each other already, unless you have firewall rules in place.
#3
Both are treated as separate interfaces and by default VyOs routes between all its interfaces (that’s the point of a router). So you have nothing to do
try “ping -I 192.168.9.1 192.168.5.1” from configure mode and you will see it responds
(this command does ping your physical interface address from the vlan interface)
#4
Thanks for reply. Response on ping between interfaces vlan adress GW and physical adress GW working properly. But my host with address vlan not pinging host with physical address.
ping -I 192.168.9.5 192.168.5.8
bind: Cannot assign requested address
What’s wrong ? NAT is required ?
#5
Do both hosts ping their respective gateway interface ?
Do they have their gateway and subnet mask correctly configured ?
How are they connected to the physical and VLAN interface ? I suppose this involve a switch, what it’s brand / model / configuration?
You should post the VyOs instance configuration and host IP settings (Windows : result of ipconfig /all ; linux result of “ip address” and “ip route”)
#6
Agree with JFL Without at least VyOS config it’s impossible to suggest
