One of our customers is running an unattended (the company that was doing the maintenance left time ago) installation of VyOS 1.1.7.
Everything was working normally, until a few days ago there was an issue with the host hardware (both the RAID card and battery had to be replaced). The system runs under VMWare.
After booting up the vm again, it didn’t configure services as before. In fact, the /config directory appears only with a default skeleton content.
I have no idea about this system (I admit it), and I’m kind of lost. I’ve been able to find the original configuration under /opt/vyatta/etc/config (which as per /etc/init.d/vyatta-router is supposed to be bind-mounted at /config on boot, but that’s not happening).
Copying all of it under /config and running manually the “/etc/init.d/vyatta-router start” script the services (mainly 3 openvpn instances and an ipsec vpn) start correctly (more or less, there’s a problem with library dependencies for openvpn-auth-ldap.so but well, 1st things 1st). But no changes are kept upon reboots and of course things must be started manually after rebooting. Since this system works heavily under those overlay/ro fs, it’s not just a simple Debian host.
After booting, the mounted fs’s are:
# df -ah
Filesystem Size Used Avail Use% Mounted on
overlayfs 249M 36M 214M 15% /
tmpfs 249M 0 249M 0% /lib/init/rw
proc 0 0 0 - /proc
sysfs 0 0 0 - /sys
udev 241M 164K 241M 1% /dev
tmpfs 249M 4.0K 249M 1% /dev/shm
devpts 0 0 0 - /dev/pts
/dev/sda1 7.8G 582M 6.8G 8% /live/image
tmpfs 249M 36M 214M 15% /live/cow
tmpfs 249M 0 249M 0% /live
tmpfs 249M 0 249M 0% /tmp
tmpfs 249M 36M 214M 15% /opt/vyatta/etc/config
fusectl 0 0 0 - /sys/fs/fuse/connections
none 249M 896K 248M 1% /opt/vyatta/config
/live/image/boot/1.1.7
7.8G 582M 6.8G 8% /boot
/live/image/boot/grub
7.8G 582M 6.8G 8% /boot/grub
I can share any other information needed.
Could this system be salvaged? Or it’s not worth the effort?
Thanks,
Rubén.
