Connection tracking
Hi, is connection tracking enabled in VyOS 1.1.8 (or later version)? Is there a way that I can see the connection tracking status? If enabled, can it be disabled or are other components defendant on it? Thanks
Hi @avdvyver, yes. Bit more you can read on VyOS docs https://docs.vyos.io/en/latest/services/conntrack.html
ps:/ 1.1.8 EOL
Thank you for the feedback.
I understand that 1.1.8 is EOL but from my point of view there are still few stability issues that I am observing when running 1.1.8 and 1.2.3 side by side and I am logging these to try and contribute to its stability. But I cannot simply decommission my 1.1.8 routers until I can at least prove that its stability is matched in 1.2.3.
Again, thanks for your assistance.
