I have two Vyos routers as VM’s and there VRRP between the two routers, recently i noticed a high cpu load on the active router the conntrackd is taking all cpu resource, i’m not sure how to check and see what is causing the issue, has anyone faced the same issue before?
I’m still facing the same issue, couldn’t really find any resource regarding this issue, i’m using the two routes to static route few subnets to the public and I don’t really use the firewall apart from the below configs:
