Disable logging of martians
#1
i would like to disable logging of martians.
Jun 9 07:06:58 seatm1corert000 kernel: [4509959.318409] IPv4: martian source 10.202.10.0 from 0.0.0.0, on dev eth0
Jun 9 07:06:58 seatm1corert000 kernel: [4509959.318412] ll header: 00000000: ff ff ff ff ff ff 00 00 00 00 fe 00 08 00
I know that it is coming from our Checkpoint FW.
I found that the configuration should be in the file:
/proc/sys/net/ipv4/conf/eth0/log_martians
but there is 0. So i am not sure where else it should be disabled.
Thank you
