Hi All,
I am a new guy in VyOS.
I want to setup a host to serve as both dmvpn hub + l2tp-ipsec server, but it failed if both configurations (dmvpn and l2tp-ipsec) co-exists. Anyone can help? Thanks.
Regards
CC Ng
Hi All,
Regards
CC Ng
Hello.
Not supported currently and no workaround available (except use something other than l2tp-ipsec)
Hi Syncer,
Noted with thanks for your information…
Any other good choice in remote access vpn? I want l2tp-ipsec is that it natively supported by Windows and Apple, as well as easy to deploy with Linux.
Is there any other good choice in VyOS? Thanks…
Thanks a lot Nikolay! I will study the blog…
SSTP also available as alternative
Thank you Syncer, I will study your suggest too and see which one is suitable for my case, thanks a lot!
