Foundet
set firewall all-ping ‘enable’
set firewall broadcast-ping ‘disable’
set firewall config-trap ‘disable’
set interfaces ethernet eth0 address ‘xxx.xxx.100.100/24’
set interfaces ethernet eth0 description ‘Local Connect’
set interfaces ethernet eth0 hw-id ‘b8:ac:6f:14:c2:16’
set interfaces ethernet eth1 address ‘xxx.xxx.56.187/29’
set interfaces ethernet eth1 description ‘ISP1’
set interfaces ethernet eth1 hw-id ‘b8:ac:6f:14:c2:18’
set interfaces ethernet eth2 hw-id ‘b8:ac:6f:14:c2:1a’
set interfaces ethernet eth3 hw-id ‘b8:ac:6f:14:c2:1c’
set interfaces ethernet eth3 vif 2138 address ‘xxx.xxx.2.98/30’
set interfaces ethernet eth3 vif 2138 description ‘ISP2-1’
set interfaces ethernet eth3 vif 2139 address ‘xxx.xxx.2.102/30’
set interfaces ethernet eth3 vif 2139 description ‘ISP2-2’
set interfaces ethernet eth4 disable
set interfaces ethernet eth4 duplex ‘full’
set interfaces ethernet eth4 hw-id ‘28:92:4a:af:31:b0’
set interfaces ethernet eth4 mtu ‘9000’
set interfaces ethernet eth4 speed ‘10000’
set interfaces ethernet eth5 address ‘xxx.xxx.176.1/23’
set interfaces ethernet eth5 address ‘xxx.xxx.88.1/24’
set interfaces ethernet eth5 address ‘xxx.xxx.24.1/23’
set interfaces ethernet eth5 address ‘xxx.xxx.182.1/24’
set interfaces ethernet eth5 address ‘xxx.xxx.177.1/24’
set interfaces ethernet eth5 address ‘xxx.xxx.25.1/24’
set interfaces ethernet eth5 address ‘xxx.xxx.181.1/24’
set interfaces ethernet eth5 description ‘10GB Port > Switch’
set interfaces ethernet eth5 disable-flow-control
set interfaces ethernet eth5 duplex ‘full’
set interfaces ethernet eth5 hw-id ‘28:92:4a:af:31:b4’
set interfaces ethernet eth5 speed ‘10000’
set interfaces ethernet eth5 vif 2200 address ‘xxx.xxx.24.249/30’
set interfaces loopback lo
Ower IPv4
set policy prefix-list IPv4-ISP2-OUT rule 100 action ‘permit’
set policy prefix-list IPv4-ISP2-OUT rule 100 description ‘AS33XXX’
set policy prefix-list IPv4-ISP2-OUT rule 100 prefix ‘xxx.xxx.181.0/24’
set policy prefix-list IPv4-ISP2-OUT rule 105 action ‘permit’
set policy prefix-list IPv4-ISP2-OUT rule 105 description ‘AS33XXX’
set policy prefix-list IPv4-ISP2-OUT rule 105 prefix ‘xxx.xxx.176.0/23’
set policy prefix-list IPv4-ISP2-OUT rule 106 action ‘permit’
set policy prefix-list IPv4-ISP2-OUT rule 106 description ‘AS33XXX’
set policy prefix-list IPv4-ISP2-OUT rule 106 prefix ‘xxx.xxx.88.0/24’
set policy prefix-list IPv4-ISP2-OUT rule 140 action ‘permit’
set policy prefix-list IPv4-ISP2-OUT rule 140 description ‘AS33XXX’
set policy prefix-list IPv4-ISP2-OUT rule 140 prefix ‘xxx.xxx.24.0/23’
set policy prefix-list IPv4-ISP2-OUT rule 150 action ‘permit’
set policy prefix-list IPv4-ISP2-OUT rule 150 description ‘AS33XXX’
set policy prefix-list IPv4-ISP2-OUT rule 150 prefix ‘xxx.xxx.182.0/24’
DownStreamer IPv4
set policy prefix-list IPv4-ISP2-OUT rule 170 action ‘permit’
set policy prefix-list IPv4-ISP2-OUT rule 170 description ‘HC - ASXXX’
set policy prefix-list IPv4-ISP2-OUT rule 170 prefix ‘xxx.xxx.26.0/24’
set policy prefix-list IPv4-ISP2-OUT rule 180 action ‘permit’
set policy prefix-list IPv4-ISP2-OUT rule 180 description ‘HC - ASXXX’
set policy prefix-list IPv4-ISP2-OUT rule 180 prefix ‘xxx.xxx.104.0/24’
set policy prefix-list IPv4-ISP2-OUT rule 190 action ‘permit’
set policy prefix-list IPv4-ISP2-OUT rule 190 description ‘HC - ASXXX’
set policy prefix-list IPv4-ISP2-OUT rule 190 prefix ‘xxx.xxx.105.0/24’
set policy prefix-list IPv4-HC-OUT rule 100 action ‘permit’
set policy prefix-list IPv4-HC-OUT rule 100 prefix ‘xxx.xxx.0.0/0’
Ower IPv4
set policy prefix-list IPv4-ISP1-OUT rule 100 action ‘permit’
set policy prefix-list IPv4-ISP1-OUT rule 100 description ‘AS33XXX’
set policy prefix-list IPv4-ISP1-OUT rule 100 prefix ‘xxx.xxx.181.0/24’
set policy prefix-list IPv4-ISP1-OUT rule 105 action ‘permit’
set policy prefix-list IPv4-ISP1-OUT rule 105 description ‘AS33XXX’
set policy prefix-list IPv4-ISP1-OUT rule 105 prefix ‘xxx.xxx.176.0/23’
set policy prefix-list IPv4-ISP1-OUT rule 140 action ‘permit’
set policy prefix-list IPv4-ISP1-OUT rule 140 description ‘AS33XXX’
set policy prefix-list IPv4-ISP1-OUT rule 140 prefix ‘xxx.xxx.24.0/23’
set policy prefix-list IPv4-ISP1-OUT rule 150 action ‘permit’
set policy prefix-list IPv4-ISP1-OUT rule 150 description ‘AS33XXX’
set policy prefix-list IPv4-ISP1-OUT rule 150 prefix ‘xxx.xxx.182.0/24’
set policy prefix-list IPv4-ISP1-OUT rule 160 action ‘permit’
set policy prefix-list IPv4-ISP1-OUT rule 160 description ‘AS33XXX’
set policy prefix-list IPv4-ISP1-OUT rule 160 prefix ‘xxx.xxx.88.0/24’
DownStreamer IPv4
set policy prefix-list IPv4-ISP1-OUT rule 170 action ‘permit’
set policy prefix-list IPv4-ISP1-OUT rule 170 description ‘HC - ASXXX’
set policy prefix-list IPv4-ISP1-OUT rule 170 prefix ‘xxx.xxx.26.0/24’
set policy prefix-list IPv4-ISP1-OUT rule 180 action ‘permit’
set policy prefix-list IPv4-ISP1-OUT rule 180 description ‘HC - ASXXX’
set policy prefix-list IPv4-ISP1-OUT rule 180 prefix ‘xxx.xxx.104.0/24’
set policy prefix-list IPv4-ISP1-OUT rule 190 action ‘permit’
set policy prefix-list IPv4-ISP1-OUT rule 190 description ‘HC - ASXXX’
set policy prefix-list IPv4-ISP1-OUT rule 190 prefix ‘xxx.xxx.105.0/24’
set policy route-map EXPORT
set policy route-map IPv4-NET-ISP2 rule 100 action ‘permit’
set policy route-map IPv4-NET-ISP2 rule 100 match ip address prefix-list ‘IPv4-ISP2-OUT’
set policy route-map IPv4-NET-ISP2 rule 105 action ‘permit’
set policy route-map IPv4-NET-ISP2 rule 105 match ip address prefix-list ‘IPv4-ISP2-OUT’
set policy route-map IPv4-NET-ISP2 rule 106 action ‘permit’
set policy route-map IPv4-NET-ISP2 rule 106 match ip address prefix-list ‘IPv4-ISP2-OUT’
set policy route-map IPv4-NET-ISP2 rule 140 action ‘permit’
set policy route-map IPv4-NET-ISP2 rule 140 match ip address prefix-list ‘IPv4-ISP2-OUT’
set policy route-map IPv4-NET-ISP2 rule 150 action ‘permit’
set policy route-map IPv4-NET-ISP2 rule 150 match ip address prefix-list ‘IPv4-ISP2-OUT’
set policy route-map IPv4-NET-ISP2 rule 170 action ‘permit’
set policy route-map IPv4-NET-ISP2 rule 170 match ip address prefix-list ‘IPv4-ISP2-OUT’
set policy route-map IPv4-NET-ISP2 rule 180 action ‘permit’
set policy route-map IPv4-NET-ISP2 rule 180 match ip address prefix-list ‘IPv4-ISP2-OUT’
set policy route-map IPv4-NET-ISP2 rule 190 action ‘permit’
set policy route-map IPv4-NET-ISP2 rule 190 match ip address prefix-list ‘IPv4-ISP2-OUT’
set policy route-map IPv4-NET-HC rule 100 action ‘permit’
set policy route-map IPv4-NET-HC rule 100 match ip address prefix-list ‘IPv4-HC-OUT’
set policy route-map IPv4-NET-ISP1 rule 100 action ‘permit’
set policy route-map IPv4-NET-ISP1 rule 100 match ip address prefix-list ‘IPv4-ISP1-OUT’
set policy route-map IPv4-NET-ISP1 rule 105 action ‘permit’
set policy route-map IPv4-NET-ISP1 rule 105 match ip address prefix-list ‘IPv4-ISP1-OUT’
set policy route-map IPv4-NET-ISP1 rule 106 action ‘permit’
set policy route-map IPv4-NET-ISP1 rule 106 match ip address prefix-list ‘IPv4-ISP1-OUT’
set policy route-map IPv4-NET-ISP1 rule 140 action ‘permit’
set policy route-map IPv4-NET-ISP1 rule 140 match ip address prefix-list ‘IPv4-ISP1-OUT’
set policy route-map IPv4-NET-ISP1 rule 150 action ‘permit’
set policy route-map IPv4-NET-ISP1 rule 150 match ip address prefix-list ‘IPv4-ISP1-OUT’
set policy route-map IPv4-NET-ISP1 rule 170 action ‘permit’
set policy route-map IPv4-NET-ISP1 rule 170 match ip address prefix-list ‘IPv4-ISP1-OUT’
set policy route-map IPv4-NET-ISP1 rule 180 action ‘permit’
set policy route-map IPv4-NET-ISP1 rule 180 match ip address prefix-list ‘IPv4-ISP1-OUT’
set policy route-map IPv4-NET-ISP1 rule 190 action ‘permit’
set policy route-map IPv4-NET-ISP1 rule 190 match ip address prefix-list ‘IPv4-ISP1-OUT’
set protocols bgp address-family ipv4-unicast network xxx.xxx.181.0/24
set protocols bgp address-family ipv4-unicast network xxx.xxx.24.0/23
set protocols bgp address-family ipv4-unicast network xxx.xxx.176.0/23
set protocols bgp address-family ipv4-unicast network xxx.xxx.182.0/24
set protocols bgp address-family ipv4-unicast network xxx.xxx.88.0/24
set protocols bgp local-as ‘339XX’
ISP1
set protocols bgp neighbor xxx.xxx.56.185 address-family ipv4-unicast route-map export ‘IPv4-NET-ISP1’
set protocols bgp neighbor xxx.xxx.56.185 address-family ipv4-unicast soft-reconfiguration inbound
set protocols bgp neighbor xxx.xxx.56.185 address-family ipv4-unicast weight ‘200’
set protocols bgp neighbor xxx.xxx.56.185 description ‘ISP1 National AS Neighbor’
set protocols bgp neighbor xxx.xxx.56.185 remote-as ‘87XX’
set protocols bgp neighbor xxx.xxx.56.185 update-source ‘xxx.xxx.56.187’
set protocols bgp neighbor xxx.xxx.56.186 address-family ipv4-unicast route-map export ‘IPv4-NET-ISP1’
set protocols bgp neighbor xxx.xxx.56.186 address-family ipv4-unicast soft-reconfiguration inbound
set protocols bgp neighbor xxx.xxx.56.186 address-family ipv4-unicast weight ‘200’
set protocols bgp neighbor xxx.xxx.56.186 description ‘ISP1 National AS Neighbor - Back-UP’
set protocols bgp neighbor xxx.xxx.56.186 remote-as ‘87XX’
set protocols bgp neighbor xxx.xxx.56.186 update-source ‘xxx.xxx.56.187’
set protocols bgp neighbor xxx.xxx.184.233 address-family ipv4-unicast route-map export ‘IPv4-NET-ISP1’
set protocols bgp neighbor xxx.xxx.184.233 address-family ipv4-unicast soft-reconfiguration inbound
set protocols bgp neighbor xxx.xxx.184.233 address-family ipv4-unicast weight ‘100’
set protocols bgp neighbor xxx.xxx.184.233 description ‘ISP1 International AS Neighbor’
set protocols bgp neighbor xxx.xxx.184.233 ebgp-multihop ‘255’
set protocols bgp neighbor xxx.xxx.184.233 remote-as ‘87XX’
set protocols bgp neighbor xxx.xxx.184.233 update-source ‘xxx.xxx.56.187’
US with Customer (Downstreamer)
set protocols bgp neighbor xxx.xxx.24.250 address-family ipv4-unicast route-map export ‘IPv4-NET-HC’
set protocols bgp neighbor xxx.xxx.24.250 address-family ipv4-unicast soft-reconfiguration
set protocols bgp neighbor xxx.xxx.24.250 address-family ipv4-unicast weight ‘200’
set protocols bgp neighbor xxx.xxx.24.250 description ‘US > HC’
set protocols bgp neighbor xxx.xxx.24.250 ebgp-multihop ‘2’
set protocols bgp neighbor xxx.xxx.24.250 remote-as ‘576XX’
set protocols bgp neighbor xxx.xxx.24.250 update-source ‘xxx.xxx.24.249’
ISP2
set protocols bgp neighbor xxx.xxx.2.97 address-family ipv4-unicast route-map export ‘IPv4-NET-ISP2’
set protocols bgp neighbor xxx.xxx.2.97 address-family ipv4-unicast soft-reconfiguration inbound
set protocols bgp neighbor xxx.xxx.2.97 address-family ipv4-unicast weight ‘200’
set protocols bgp neighbor xxx.xxx.2.97 description ‘ISP2 1’
set protocols bgp neighbor xxx.xxx.2.97 remote-as ‘66XX’
set protocols bgp neighbor xxx.xxx.2.97 update-source ‘xxx.xxx.2.98’
set protocols bgp neighbor xxx.xxx.2.101 address-family ipv4-unicast route-map export ‘IPv4-NET-ISP2’
set protocols bgp neighbor xxx.xxx.2.101 address-family ipv4-unicast soft-reconfiguration inbound
set protocols bgp neighbor xxx.xxx.2.101 address-family ipv4-unicast weight ‘200’
set protocols bgp neighbor xxx.xxx.2.101 description ‘ISP2 2’
set protocols bgp neighbor xxx.xxx.2.101 remote-as ‘66XX’
set protocols bgp neighbor xxx.xxx.2.101 update-source ‘xxx.xxx.2.102’
set protocols bgp neighbor xxx.xxx.200.12 address-family ipv4-unicast route-map export ‘IPv4-NET-ISP2’
set protocols bgp neighbor xxx.xxx.200.12 address-family ipv4-unicast soft-reconfiguration inbound
set protocols bgp neighbor xxx.xxx.200.12 address-family ipv4-unicast weight ‘100’
set protocols bgp neighbor xxx.xxx.200.12 description ‘ISP2 International’
set protocols bgp neighbor xxx.xxx.200.12 ebgp-multihop ‘255’
set protocols bgp neighbor xxx.xxx.200.12 remote-as ‘66XX’
set protocols bgp neighbor xxx.xxx.200.12 update-source ‘xxx.xxx.2.98’
set protocols bgp parameters log-neighbor-changes
set protocols ospf area 0 network ‘xxx.xxx.176.0/23’
set protocols ospf area 0 network ‘xxx.xxx.181.0/24’
set protocols ospf area 0 network ‘xxx.xxx.88.0/24’
set protocols ospf area 0 network ‘xxx.xxx.24.0/23’
set protocols ospf area 0 network ‘xxx.xxx.182.0/24’
set protocols ospf area xxx.xxx.0.0 area-type normal
set protocols ospf default-information originate always
set protocols ospf default-information originate metric ‘10’
set protocols ospf default-information originate metric-type ‘2’
set protocols ospf parameters abr-type ‘cisco’
set protocols static route xxx.xxx.181.0/24 blackhole distance ‘254’
set protocols static route xxx.xxx.24.0/23 blackhole distance ‘254’
set protocols static route xxx.xxx.176.0/23 blackhole distance ‘254’
set protocols static route xxx.xxx.182.0/24 blackhole distance ‘254’
set protocols static route xxx.xxx.88.0/24 blackhole distance ‘254’
set protocols static route xxx.xxx.200.12/32 next-hop xxx.xxx.2.97
set service ids ddos-protection alert-script ‘/usr/local/bin/notify_script.bash’
set service ids ddos-protection direction ‘in’
set service ids ddos-protection listen-interface ‘eth1’
set service ids ddos-protection listen-interface ‘eth3.2138’
set service ids ddos-protection listen-interface ‘eth3.2139’
set service ids ddos-protection mode mirror
set service ids ddos-protection network ‘xxx.xxx.176.0/23’
set service ids ddos-protection network ‘xxx.xxx.181.0/24’
set service ids ddos-protection network ‘xxx.xxx.24.0/23’
set service ids ddos-protection network ‘xxx.xxx.88.0/24’
set service ids ddos-protection network ‘xxx.xxx.182.0/24’
set service ids ddos-protection network ‘xxx.xxx.26.0/24’
set service ids ddos-protection network ‘xxx.xxx.104.0/24’
set service ids ddos-protection network ‘xxx.xxx.105.0/24’
set service ids ddos-protection threshold fps ‘3500’
set service ids ddos-protection threshold mbps ‘350’
set service ids ddos-protection threshold pps ‘25000’
set system flow-accounting interface ‘eth1’
set system flow-accounting interface ‘eth3.2138’
set system flow-accounting interface ‘eth3.2139’
