Hello!
I am trying to build the latest rolling release and running into an apt issue:
gnupg is already the newest version (2.2.40-1).
Some packages could not be installed. This may mean that you have
libvyatta-cfg1 : Depends: perlapi-5.32.1 but it is not installable
Depends: libperl5.32 (>= 5.32.0~rc1) but it is not installable
vyos-1x : Depends: crda but it is not installable
Depends: keepalived (>= 2.0.5) but it is not going to be installed
Depends: libbpf0 but it is not installable
Depends: libstrongswan-standard-plugins (>= 5.9) but it is not going to be installed
Depends: libvyosconfig0 but it is not going to be installed
P: Saving caches...
Reading package lists... Done
Any help would be great!
