if I apply the following firewall policie with the command
set interfaces ethernet eth0 firewall local ipv6-name OUTSIDE-LOCALv6
the ipv6 traffic of all devices behind the vyos router is blocked. I have the same policie for ipv4(with nat) which is working just fine.
ipv6-name OUTSIDE-LOCALv6 {
default-action drop
rule 100 {
action accept
state {
established enable
related enable
rule 200 {
action accept
icmpv6 {
type echo-request
protocol icmpv6Preformatted text
state {
new enable
rule 300 {
action accept
description “Wireguard VPN”
destination {
port 51820
protocol udp
If this policie is enabeld, the vyos router and devices behind it can’t ping ipv6 adresses outside the LAN.
