Could you please add such detailes to netfilter bug?
https://bugzilla.netfilter.org/show_bug.cgi?id=1737
Funny you should ask, because I tried creating an account which is only available via email. Still waiting. I also included what I posted here in that email.
Cheers
In case you’re using time based firewall rules. I am currently working around this issue by using scripts and schedules. Not pretty but works for now. Can also modify script to make it more generic to accept the rule number.
Create script file:
/config/scripts/enablefw.sh
#!/bin/vbash
VALUE=$1
if [ "$VALUE" = "enable" ]; then
configure
delete firewall ipv4 name LAN-WAN rule 260 disable
delete firewall ipv4 name LAN-WAN rule 270 disable
delete firewall ipv4 name LAN-WAN rule 271 disable
commit
exit
elif [ "$VALUE" = "disable" ]; then
configure
set firewall ipv4 name LAN-WAN rule 260 disable
set firewall ipv4 name LAN-WAN rule 270 disable
set firewall ipv4 name LAN-WAN rule 271 disable
commit
exit
fi
Then I created some schedules to interact with the script
set system task-scheduler task disable_timed_rule crontab-spec '30 22 * * SUN'
set system task-scheduler task disable_timed_rule executable arguments 'disable'
set system task-scheduler task disable_timed_rule executable path '/config/scripts/enablefw.sh'
set system task-scheduler task enable_timed_rule crontab-spec '30 16 * * FRI'
set system task-scheduler task enable_timed_rule executable arguments 'enable'
set system task-scheduler task enable_timed_rule executable path '/config/scripts/enablefw.sh'
Hi n.fort:
Curious to know what the chances or process of getting this implemented?
https://bugzilla.netfilter.org/show_bug.cgi?id=1737](https://bugzilla.netfilter.org/show_bug.cgi?id=1737)
Seems they’ve created a patch:
https://patchwork.ozlabs.org/project/netfilter-devel/patch/20240319192609.218891-1-pablo@netfilter.org/
I also noticed they are using a range command which is not used within VyOS.
e.g.
chain NAME_LAN-WAN {
ct state {new} meta l4proto icmp ip saddr 192.168.100.99 icmp type echo-request hour "09:00:00"-"10:00:00" log prefix "[ipv4-NAM-LAN-WAN-100-A]" counter accept comment "ipv4-NAM-LAN-WAN-100"
Kind Regards
I’ll give it a look! Thanks for letting us know about the patch
