I`m a vyos Newbie, but how can I get the default settings for example for “firewall broadcast-ping” or “firewall log-martians” are they enabled or disabled without any special setting?
Some firewall nodes are added automatically to the configuration with their default value. To reset a node to its default, simply delete it. delete firewall broadcast-ping
Ok, but what is the default, is it enabled or disabled? I didn’t found it somewhere documented.
For ‘all-ping’ it is written down, but not for the oher options.
Whis show configuration i can only find my settings, but not the default settings.
show configuration all
= “Show running configuration (including default values)”
