Gre tunnel work on single core?
hello everyone
gre tunnel work on single core ?
because i using +150kpps on gre tunnel and my single core overloaded
when ddos is come from gre tunnel 70-80k pps gre tunnel cpu overloaded to %70
i using i9-9900k processor and vyos directly installed to this dedicated server
Try to enable rps
set interfaces ethernet eth0 offload rps
after gre tunnel can work on multi core ?
i tried this but it got worse
Could you try to add the following optimisation and compare results?
sudo su -l
echo "ff" > /sys/class/net/tun0/queues/rx-0/rps_cpus
Note: You need to disable HT
Also increase ring buffers. Bit more about system optimisation you can read by the following link System optimization - Knowledgebase / General / System Settings - VyOS
i need to reactive again this ?
“set interfaces ethernet eth0 offload rps”
i get same results my cpu overloaded
i tried offload rps and echo “ff” > /sys/class/net/tun0/queues/rx-0/rps_cpus its not successfuly
i will try disable hyperthreading
i get +600k pps attack from gre tunnel and my tunnel cpu overloaded network down
after disable hyperthreading on getting 850k pps attack from tunnel
results;
hello sir
my problem still next
i live same problem on gre tunnel, emergency!
can i get help about my problem ? @Dmitry @Viacheslav
Which address destination? Is it address of gre tunnel itself or ip adressses behind tunnel?
Is traffic generated from different source ip or source IP address was same?
i send my tunnel settings on dm
getting attack to my prefixes on tunnel
is traffic generater from different source ip and destination my prefixes /24
i didnt get attack to my tunnel ip
hello. i waiting good news about this problem
@Viacheslav
I don’t test it with gre, not sure but it can help. Enable some of these offloads.
sudo ethtool -K eth1 gro on
sudo ethtool -K eth1 sg on
sudo ethtool -K eth1 tso on
sudo ethtool -K eth1 lro on
As I know to resolve hardware Optimizations for tunnels rss/udp checksum/ etc. used a new feature FOO-over-UDP. T3597
Do you still see load only on one core?
i will try this now and tell you results
i tried this still work on single core,
i think its a kernel problem
