Help.About PPPoE performance
Hello everyone!
I am using the Spirent TestCenter to test the forwarding performance of PPPoE. The test network is as follows:
Interface Eth4 and Interface Eth5 are both 10Gbps network cards, connected to the TestCenter separately, and then establish 8 PPPoE sessions each. Then the tester streams from one port and receives from another port, covering all PPPoE sessions.
Each interface is streamed at 50% of the bandwidth.
The PPPoE session establishment information is as follows:
I have configured RPS on the interface Eth4 and Eth5.The TX queue has taken effect, but it seems that the RX queue has not taken effect.
Only the rx_queue_0 in the receiving queue has data, the others have no data.
The information of the “top” command is as follows:
What configurations should I do for performance optimization?Looking forward to your help。
Please, show
sudo ethtool -k eth4
sudo ethtool -k eth5
ibng@iBNG:~$
ibng@iBNG:~$ ethtool -k eth4
Features for eth4:
rx-checksumming: on
tx-checksumming: on
tx-checksum-ipv4: on
tx-checksum-ip-generic: off [fixed]
tx-checksum-ipv6: on
tx-checksum-fcoe-crc: off [fixed]
tx-checksum-sctp: on
scatter-gather: off
tx-scatter-gather: off
tx-scatter-gather-fraglist: off [fixed]
tcp-segmentation-offload: off
tx-tcp-segmentation: off
tx-tcp-ecn-segmentation: off
tx-tcp-mangleid-segmentation: off
tx-tcp6-segmentation: off
generic-segmentation-offload: off
generic-receive-offload: off
large-receive-offload: off [fixed]
rx-vlan-offload: on
tx-vlan-offload: on
ntuple-filters: on
receive-hashing: on
highdma: on
rx-vlan-filter: on
vlan-challenged: off [fixed]
tx-lockless: off [fixed]
netns-local: off [fixed]
tx-gso-robust: off [fixed]
tx-fcoe-segmentation: off [fixed]
tx-gre-segmentation: on
tx-gre-csum-segmentation: on
tx-ipxip4-segmentation: on
tx-ipxip6-segmentation: on
tx-udp_tnl-segmentation: on
tx-udp_tnl-csum-segmentation: on
tx-gso-partial: on
tx-tunnel-remcsum-segmentation: off [fixed]
tx-sctp-segmentation: off [fixed]
tx-esp-segmentation: off [fixed]
tx-udp-segmentation: on
tx-gso-list: off [fixed]
fcoe-mtu: off [fixed]
tx-nocache-copy: off
loopback: off
rx-fcs: off
rx-all: off [fixed]
tx-vlan-stag-hw-insert: off
rx-vlan-stag-hw-parse: off
rx-vlan-stag-filter: on
l2-fwd-offload: off [fixed]
hw-tc-offload: off
esp-hw-offload: off [fixed]
esp-tx-csum-hw-offload: off [fixed]
rx-udp_tunnel-port-offload: on
tls-hw-tx-offload: off [fixed]
tls-hw-rx-offload: off [fixed]
rx-gro-hw: off [fixed]
tls-hw-record: off [fixed]
rx-gro-list: off
macsec-hw-offload: off [fixed]
rx-udp-gro-forwarding: off
hsr-tag-ins-offload: off [fixed]
hsr-tag-rm-offload: off [fixed]
hsr-fwd-offload: off [fixed]
hsr-dup-offload: off [fixed]
ibng@iBNG:~$
ibng@iBNG:~$ ethtool -k eth5
Features for eth5:
rx-checksumming: on
tx-checksumming: on
scatter-gather: off
rx-vlan-offload: on
tx-vlan-offload: on
ntuple-filters: on
receive-hashing: on
highdma: on
rx-vlan-filter: on
tx-gso-partial: on
loopback: off
rx-fcs: off
rx-all: off [fixed]
hw-tc-offload: off
rx-gro-list: off
ibng@iBNG:~$
Thanks!
I suspect that the RX queue may not have been hashed due to PPPoE encapsulation.
First, I recommend looking at your network card documentation and finding what hashing algorithm it can use.
Maybe it is possible to configure RSS to distribute RX PPP packets on different queues.
If it is possible, then you can use ethtool -N to configure it.
Otherwise enabling RPS is enough in your case.
There seems to be no way in this scenario.
While you are at it it would have been interesting to see the result of the other offloading options if you enable/disable one at a time?
Hash different packets into different RX queues based on the source Mac address。
ethtool -U flow-type ether src xx xx
This is marked as answered, wondered if it was actually resolved and if so what the fix was?
We have changed our approach to solving this problem。
