Hostfiles return wrong dns record
Hi, All
I just setup 2 vyos with dhcp on failover mode,two dns one eache node, and set hostfile-update and host-declname enable
but there are alway some hostname and ip are not mached. seem like one dns reture wrong. here is my configuration.
Like this, 10.32.0.18 return the right dns record. 10.32.0.8 return wrong dns record.
 echowings@macbookpro  ~  nslookup  ssql08r2orcl10 10.32.0.18
Server:		10.32.0.18
Address:	10.32.0.18#53
Non-authoritative answer:
Address: 10.32.3.117
 echowings@macbookpro  ~  nslookup  ssql08r2orcl10 10.32.0.8
Server:		10.32.0.8
Address:	10.32.0.8#53
Address: 10.32.2.58
my vyos version is the offical release version:
vyos@xadns-10.32.0.8:~$ show version
Version:          VyOS 1.2.1
Built by:         Sentrium S.L.
Built on:         Sun 14 Apr 2019 12:13 UTC
Build ID:         4ccd819a-db31-452e-b34b-a0b24af4e984
Architecture:     x86_64
System type:      KVM guest
Hardware vendor:  QEMU
Hardware model:   Standard PC (i440FX + PIIX, 1996)
Hardware S/N:     Unknown
Hardware UUID:    Unknown
# vyos01 --10.32.0.8
    dhcp-server {
        hostfile-update
        host-decl-name
        shared-network-name gclan {
            subnet 10.32.0.0/22 {
                default-router 10.32.0.252
                dns-server 10.32.0.8
                domain-name grapecity.net
                domain-search grapecity.net
                failover {
                    local-address 10.32.0.8
                    name gclanfailover
                    peer-address 10.32.0.18
                    status primary
                ntp-server 10.32.0.2
                ntp-server 10.32.0.3
                range 0 {
                    start 10.32.1.0
                    stop 10.32.3.254
# vyos 02 -10.32.0.18
service {
    dhcp-server {
        hostfile-update
        host-decl-name
                dns-server 10.32.0.18
                failover {
                    local-address 10.32.0.18
                    name gclanfailover
                    peer-address 10.32.0.8
                    status secondary
                range 0 {
                    start 10.32.1.0
                    stop 10.32.3.254
vyos@xadns-10.32.0.8:~$ show dhcp server statistics
Pool      Size    Leases    Available  Usage
gclan      766       232          534  0%
gcwpa2     766       232          534  0%
Closed, because of: ⚓ T1416 2 dhcp server run in failover mode can't sync hostname with each other
