How do I define PSK in vyos 1.4
Hi Team,
I am defining policy based tunnel on vyos 1.4.2 and wondering what is the way to define PSK in 1.4.x version per peer.
there is no VyOS version 1.4.2 (yet), also with a missing config example/diagram it will be hard to tell. Please submit a config snippet that you plan and a topology diagram
Ok - This is my existing config on vyos 1.3
set vpn ipsec esp-group ESP compression 'disable'
set vpn ipsec esp-group ESP lifetime '3600'
set vpn ipsec esp-group ESP mode 'tunnel'
set vpn ipsec esp-group ESP pfs 'enable'
set vpn ipsec esp-group ESP proposal 1 encryption 'aes256'
set vpn ipsec esp-group ESP proposal 1 hash 'sha1'
set vpn ipsec ike-group IKE close-action 'none'
set vpn ipsec ike-group IKE dead-peer-detection action 'restart'
set vpn ipsec ike-group IKE dead-peer-detection interval '15'
set vpn ipsec ike-group IKE dead-peer-detection timeout '30'
set vpn ipsec ike-group IKE ikev2-reauth 'yes'
set vpn ipsec ike-group IKE key-exchange 'ikev2'
set vpn ipsec ike-group IKE lifetime '28800'
set vpn ipsec ike-group IKE proposal 1 dh-group '2'
set vpn ipsec ike-group IKE proposal 1 encryption 'aes256'
set vpn ipsec ike-group IKE proposal 1 hash 'sha1'
set vpn ipsec site-to-site peer xx.xx.xx.xx authentication mode 'pre-shared-secret'
set vpn ipsec site-to-site peer xx.xx.xx.xx authentication pre-shared-secret 'xxxxxxxxxxxxxxx16ma'
set vpn ipsec site-to-site peer xx.xx.xx.xx connection-type 'initiate'
set vpn ipsec site-to-site peer xx.xx.xx.xx ike-group 'IKE'
set vpn ipsec site-to-site peer xx.xx.xx.xx ikev2-reauth 'inherit'
set vpn ipsec site-to-site peer xx.xx.xx.xx local-address 'xx.xx.xx.xx'
set vpn ipsec site-to-site peer xx.xx.xx.xx tunnel 2 allow-nat-networks 'disable'
set vpn ipsec site-to-site peer xx.xx.xx.xx tunnel 2 allow-public-networks 'disable'
set vpn ipsec site-to-site peer xx.xx.xx.xx tunnel 2 esp-group 'ESP'
set vpn ipsec site-to-site peer xx.xx.xx.xx tunnel 2 local prefix '192.168.11.0/24'
set vpn ipsec site-to-site peer xx.xx.xx.xx tunnel 2 remote prefix '192.168.12.0/24'
Now if you see I am specifically interested in
I do not see in vyos 1.4
Any idea if that command or syntaxes have been chnaged?
yes, you need to created it with set ipsec vpn authentication xxx , here is an example:
# Pre-shared-secret
set vpn ipsec authentication psk vyos id 192.0.2.10
set vpn ipsec authentication psk vyos id 203.0.113.45
set vpn ipsec authentication psk vyos secret MYSECRETKEY
more information about it :
https://docs.vyos.io/en/sagitta/configuration/vpn/ipsec.html
