Quick question.
If you apply a DNAT and a Zone-based policy from WAN to LAN its suppose LAN policy are expecting that packet come from WAN or from LOCAL?.
I’m trying to do a DNAT I receive the packets when I run “monitor nat dest” but I don’t see anything going out from the LAN interface.
My configuration:
firewall {
all-ping enable
broadcast-ping disable
config-trap disable
ipv6-src-route disable
ip-src-route disable
log-martians enable
name lan-wan {
default-action accept
name vpn-lan {
name vpn-wan {
default-action drop
rule 1 {
action accept
state {
established enable
related enable
rule 2 {
action reject
log enable
name wan-dmz {
default-action drop
enable-default-log
rule 1 {
action accept
state {
established enable
related enable
rule 2 {
action drop
state {
invalid enable
rule 100 {
action accept
destination {
port 3341
protocol tcp
state {
new enable
name wan-lan {
default-action drop
enable-default-log
rule 1 {
action accept
state {
established enable
related enable
rule 2 {
action drop
log enable
state {
invalid enable
rule 100 {
action accept
destination {
address 10.10.5.14
log enable
state {
new enable
send-redirects enable
source-validation disable
syn-cookies enable
address 170.xxxxx
duplex auto
hw-id 00:xxx
smp_affinity auto
speed auto
address 10.10.5.1/24
duplex auto
hw-id 00:50xxxx
smp_affinity auto
speed auto
loopback lo {
tunnel tun0 {
encapsulation gre
local-ip 140.xxxx
multicast disable
remote-ip 177.xxxx
vti vti0 {
address 169.254.252.2/30
load-balancing {
wan {
disable-source-nat
interface-health vti0 {
failure-count 10
nexthop 169.254.252.1
success-count 1
test 10 {
resp-time 5
target 169.254.252.1
ttl-limit 5
type ping
rule 10 {
inbound-interface eth0
interface vti0 {
weight 1
protocol all
nat {
destination {
rule 100 {
destination {
port 3341
log enable
protocol tcp
translation {
address 10.10.5.14
port 1433
rule 101 {
destination {
port 1433
protocol tcp
translation {
address 10.10.5.14
rule 100 {
outbound-interface eth0
address 10.10.5.0/24
translation {
address masquerade
protocols {
static {
route 172.16.0.0/16 {
next-hop 169.254.252.1 {
service {
ssh {
port 22
system {
config-management {
commit-revisions 20
console {
device ttyS0 {
speed 9600
gateway-address xxxxxx
host-name fw
name-server
name-serverpackage { auto-sync 1 repository community { components main distribution helium password "" username "" } } syslog { global { facility all { level notice } facility protocols { level debug } } } time-zone UTC
vpn {
ipsec {
esp-group MyESPGroup {
compression disable
lifetime 3600
mode tunnel
pfs enable
proposal 1 {
encryption aes128
hash sha1
proposal 2 {
encryption aes256
hash sha1
proposal 3 {
encryption 3des
hash md5
ike-group MyIKEGroup {
ikev2-reauth no
key-exchange ikev1
lifetime 28800
proposal 1 {
encryption aes256
hash sha1
proposal 2 {
encryption aes256
hash sha1
proposal 3 {
encryption 3des
hash md5
ipsec-interfaces {
interface eth0
nat-networks {
allowed-network 0.0.0.0/0 {
nat-traversal enable
site-to-site {
peer xxxxx {
authentication {
mode pre-shared-secret
pre-shared-secret xxxx
connection-type initiate
ikev2-reauth inherit
local-address xxxx
vti {
bind vti0
l2tp {
remote-access {
authentication {
local-users {
username xxxx {
password xxx
username xxx {
password xxxx
mode local
client-ip-pool {
start 192.168.214.1
stop 192.168.214.255
description xsxw
dns-servers {
server-1 8.8.8.8
ipsec-settings {
authentication {
pre-shared-secret xwxwx
ike-lifetime 3600
outside-address xxxxxxxxxxx
zone-policy {
zone lan {
default-action drop
from vpn {
firewall {
name vpn-lan
from wan {
firewall {
name wan-lan
interface eth1
zone vpn {
default-action drop
from lan {
firewall {
name vpn-lan
interface vti0
zone wan {
default-action drop
from lan {
firewall {
name lan-wan
interface eth0
Thanks.
