Hi Vyos Forum,
any idea how to implement a WAF for protect exposed services
Greetz
Hi Vyos Forum,
Greetz
Well first of all I’ll just leave this here - personally having run/used them before I think they end up being much, much more trouble than they’re worth and give you a mostly false sense of security.
THAT SAID, I realise many orgs have a requirement for one.
So you could look at using Vyos’ containter function and running something like https://www.tigera.io/blog/using-web-application-firewall-at-container-level-for-network-based-threats/
thanks for this useful hint
To do WAF’s at scale you need to either use a hardwarebased plattform such as PaloAlto Networks who offloads to ASIC/FGPA’s to do the heavy lifting.
Or something like this example where Arista were used to split up traffic over multiple installations of Bro to do the processing:
maybe this helps with your idea.
