It works only for 1.3 1.4
Got it. Thanks! Waiting vyos 1.3 release.
@echowings It wonât be difficult to add this to the next LTS release.
I can create a .deb pkg for 1.2.7 with this feature. If you can/want to check and test it.
In the local test it works fine
vyos@r2-lts:~$ show conf com | match "policy|bgp"
set policy route-map FOO rule 10 action 'permit'
set policy route-map FOO rule 10 set table '120'
set protocols bgp 65001 neighbor 192.168.122.14 address-family ipv4-unicast route-map import 'FOO'
set protocols bgp 65001 neighbor 192.168.122.14 remote-as '65002'
vyos@r2-lts:~$
vyos@r2-lts:~$ show ip bgp sum
IPv4 Unicast Summary:
BGP router identifier 192.168.122.12, local AS number 65001 vrf-id 0
BGP table version 4
RIB entries 3, using 552 bytes of memory
Peers 1, using 20 KiB of memory
Neighbor V AS MsgRcvd MsgSent TblVer InQ OutQ Up/Down State/PfxRcd
192.168.122.14 4 65002 7 8 0 0 0 00:03:00 2
Total number of neighbors 1
vyos@r2-lts:~$
vyos@r2-lts:~$ show ip route table 120
F - PBR, f - OpenFabric,
> - selected route, * - FIB route, q - queued route, r - rejected route
VRF default table 120:
B>* 192.0.2.0/24 [20/0] via 192.168.122.14, eth0, 00:00:36
B>* 203.0.113.0/24 [20/0] via 192.168.122.14, eth0, 00:00:36
vyos@r2-lts:~$
vyos@r2-lts:~$ show version
Version: VyOS 1.2.7
when youâre up and running could you share how youâve managed to LB across 2 (or more) wg interfaces please?
It will be in the next LTS release.
@Viacheslav Could you please share with me about set protocols static table 100
settings? I canât see details about table 100
For set protocols bgp 65001 maximum-paths ibgp '2'
There isnât any maximu-paths
vyos@vyos# set protocols bgp 65001
Possible completions:
> address-family
BGP address-family parameters
+> neighbor BGP neighbor
> parameters BGP parameters
+> peer-group BGP peer-group
route-map Filter routes installed in local route map
> timers BGP protocol timers
It was moved to address-family
Thanks
set protocols bgp 65001 address-family ipv4-unicast maximum-paths ibgp '2'
@Viacheslav Here is my configuration .but it isnât works for me.
set interfaces ethernet eth0 address '100.64.0.2/30'
set interfaces ethernet eth0 hw-id '50:00:00:02:00:00'
set interfaces ethernet eth1 address '192.168.2.1/24'
set interfaces ethernet eth1 hw-id '50:00:00:02:00:01'
set interfaces ethernet eth2 hw-id '50:00:00:02:00:02'
set interfaces ethernet eth3 hw-id '50:00:00:02:00:03'
set interfaces loopback lo
set interfaces wireguard wg01 address '10.10.10.254/32'
set interfaces wireguard wg01 peer cloud1 address '203.0.113.254'
set interfaces wireguard wg01 peer cloud1 allowed-ips '0.0.0.0/0'
set interfaces wireguard wg01 peer cloud1 port '8000'
set interfaces wireguard wg01 peer cloud1 pubkey 'ugeluxTvZkvRt6Py1SJDX0XRfxrF/ifZ0muh9GStH1c='
set interfaces wireguard wg02 address '10.20.20.254/32'
set interfaces wireguard wg02 peer cloud2 address '198.51.100.254'
set interfaces wireguard wg02 peer cloud2 allowed-ips '0.0.0.0/0'
set interfaces wireguard wg02 peer cloud2 port '8000'
set interfaces wireguard wg02 peer cloud2 pubkey 'XGBDUlgTZ+lgCgPR+YB9kQxtuG3Hxt5mEktIeVFgNAc='
set nat source rule 100 outbound-interface 'wg01'
set nat source rule 110 outbound-interface 'wg02'
set nat source rule 110 translation address 'masquerade'
set policy route PBR rule 10 destination address '!192.168.2.0/24'
set policy route PBR rule 10 set table '100'
set policy route PBR rule 10 source address '192.168.2.0/24'
set policy route-map RMAP-IN rule 100 action 'permit'
set policy route-map RMAP-IN rule 100 set table '100'
set protocols bgp 65001 neighbor 10.10.10.1 remote-as '65001'
set protocols bgp 65001 neighbor 10.10.10.1 timers holdtime '30'
set protocols bgp 65001 neighbor 10.10.10.1 timers keepalive '30'
set protocols bgp 65001 neighbor 10.10.10.1 update-source '10.10.10.254'
set protocols bgp 65001 neighbor 10.20.20.1 remote-as '65001'
set protocols bgp 65001 neighbor 10.20.20.1 timers holdtime '30'
set protocols bgp 65001 neighbor 10.20.20.1 timers keepalive '10'
set protocols bgp 65001 neighbor 10.20.20.1 update-source '10.20.20.254'
set protocols rip network '100.64.0.0/30'
set protocols rip network '192.168.2.0/24'
set protocols static interface-route 0.0.0.0/0 next-hop-interface wg01
set protocols static interface-route 0.0.0.0/0 next-hop-interface wg02
set protocols static interface-route 10.10.10.0/24 next-hop-interface wg01
set protocols static interface-route 10.20.20.0/24 next-hop-interface wg02
set service dhcp-server shared-network-name LAN-DHCP subnet 192.168.2.0/24 default-router '192.168.2.1'
server '192.168.2.1'
set service dhcp-server shared-network-name LAN-DHCP subnet 192.168.2.0/24 range 0 start '192.168.2.11'
set service dhcp-server shared-network-name LAN-DHCP subnet 192.168.2.0/24 range 0 stop '192.168.2.12'
set system host-name 'vyos'
set system login user vyos authentication encrypted-password '$6$p96vCymIVf.pAsYW$KWwo.AM/PF7psfABBHWwAeryXwB0YE74Ns/wK6VhKf0OtKpWgejY6m/ZTGlJAjg9s9ZTQFV.kF91r7KzQULCq0'
set system ntp server time1.vyos.net
set system ntp server time2.vyos.net
set system ntp server time3.vyos.net
BGP are fine
yos@vyos# run show bgp summary
BGP router identifier 192.168.2.1, local AS number 65001 vrf-id 0
BGP table version 0
RIB entries 0, using 0 bytes of memory
Peers 2, using 43 KiB of memory
Neighbor V AS MsgRcvd MsgSent TblVer InQ OutQ Up/Down State/PfxRcd PfxSnt
10.10.10.1 4 65001 523 525 0 0 0 01:26:42 0 0
10.20.20.1 4 65001 116 123 0 0 0 00:00:27 0 0
Total number of neighbors 2
After run command
sudo vtysh -c "conf t" -c "route-map RMAP-IN permit 100" -c " set table 100"
sudo vtysh -c "conf t" -c "router bgp 65001" -c "address-family ipv4 unicast" -c "neighbor 10.10.10.1 route-map RMAP-IN in" -c "neighbor 10.20.20.1 route-map RMAP-IN in"
then to check route table is empty.
vyos@vyos# run show ip route table 100
vyos@vyos#
Could you please tell me how to figure out this issue. Thanks a lot!
Hi @Viacheslav ,
Would you kindly tell me how to set route table like this?
vyos@vyos:~$ show ip route table 100
VRF default table 100:
B>* 0.0.0.0/0 [200/0] via 10.10.10.1, wg0, 00:00:10
* via 10.20.20.1, wg1, 00:00:10
vyos@vyos:~$
Sorry, I canât find the routing table on the configure you provide to me.
And this is the most import setting in the solution. So would do me a favor?
FRR setting
vyos# show running-config
Building configuration...
Current configuration:
frr version 7.5.1-20211211-00-g294410782
frr defaults traditional
hostname vyos
log syslog
log facility local7
service integrated-vtysh-config
router rip
network 100.64.0.0/30
network 192.168.2.0/24
router bgp 65001
no bgp ebgp-requires-policy
no bgp network import-check
neighbor 10.10.10.1 remote-as 65001
neighbor 10.10.10.1 update-source 10.10.10.254
neighbor 10.10.10.1 timers 10 30
neighbor 10.20.20.1 remote-as 65001
neighbor 10.20.20.1 update-source 10.20.20.254
neighbor 10.20.20.1 timers 10 30
maximum-paths ibgp 2
exit-address-family
set table 100
line vty
vyos@vyos# run show version
Version: VyOS 1.3.0
Release train: equuleus
Built by: Sentrium S.L.
Built on: Sun 19 Dec 2021 12:59 UTC
Build UUID: ff458f8a-3ef7-453c-a7f9-4aeb6d03012e
Build commit ID: 2f691bb2f61e96-dirty
Architecture: x86_64
Boot via: installed image
System type: KVM guest
Hardware vendor: QEMU
Hardware S/N:
Hardware UUID: abe8f380-36c1-401b-ad82-68f0bddef5fb
run show ip bgp sum
BGP router identifier 192.168.2.1, local AS number 65001 vrf-id 0or 10.20.20.1 ro
BGP table version 0
10.10.10.1 4 65001 28 29 0 0 0 00:04:17 0 0
10.20.20.1 4 65001 28 29 0 0 0 00:04:16 0 0
Neighbours should sent you default routes
Actually, I build the same lab environment as you did.
run show ip route
S>* 10.10.10.0/24 [1/0] is directly connected, wg01, weight 1, 00:04:42
C>* 10.10.10.254/32 is directly connected, wg01, 00:04:42
S>* 10.20.20.0/24 [1/0] is directly connected, wg02, weight 1, 00:04:42
C>* 10.20.20.254/32 is directly connected, wg02, 00:04:43
C>* 100.64.0.0/30 is directly connected, eth0, 00:04:45
C>* 192.168.2.0/24 is directly connected, eth1, 00:04:46
S>* 198.51.100.254/32 [1/0] via 100.64.0.1, eth0, weight 1, 00:04:41
S>* 203.0.113.254/32 [1/0] via 100.64.0.1, eth0, weight 1, 00:04:41
vyos@vyos# run show bgp neighbors
BGP neighbor is 10.10.10.1, remote AS 65001, local AS 65001, internal link
Hostname: cloud1
BGP version 4, remote router ID 203.0.113.254, local router ID 192.168.2.1
BGP state = Established, up for 00:08:12
Last read 00:00:02, Last write 00:00:02
Hold time is 30, keepalive interval is 10 seconds
Configured hold time is 30, keepalive interval is 10 seconds
Neighbor capabilities:
4 Byte AS: advertised and received
AddPath:
IPv4 Unicast: RX advertised IPv4 Unicast and received
Route refresh: advertised and received(old & new)
Address Family IPv4 Unicast: advertised and received
Hostname Capability: advertised (name: vyos,domain name: n/a) received (name: cloud1,domain name: n/a)
Graceful Restart Capability: advertised and received
Remote Restart timer is 120 seconds
Address families by peer:
none
Graceful restart information:
End-of-RIB send: IPv4 Unicast
End-of-RIB received: IPv4 Unicast
Local GR Mode: Helper*
Remote GR Mode: Helper
R bit: False
Timers:
Configured Restart Time(sec): 120
Received Restart Time(sec): 120
IPv4 Unicast:
F bit: False
End-of-RIB sent: Yes
End-of-RIB sent after update: Yes
End-of-RIB received: Yes
Timers:
Configured Stale Path Time(sec): 360
Message statistics:
Inq depth is 0
Outq depth is 0
Sent Rcvd
Opens: 1 1
Notifications: 0 0
Updates: 1 1
Keepalives: 50 50
Route Refresh: 0 0
Capability: 0 0
Total: 52 52
Minimum time between advertisement runs is 0 seconds
Update source is 10.10.10.254
For address family: IPv4 Unicast
Update group 1, subgroup 1
Packet Queue length 0
Community attribute sent to this neighbor(all)
0 accepted prefixes
Connections established 1; dropped 0
Last reset 00:08:14, Waiting for peer OPEN
Local host: 10.10.10.254, Local port: 45143
Foreign host: 10.10.10.1, Foreign port: 179
Nexthop: 10.10.10.254
Nexthop global: fe80::f8f5:cbff:fe74:cf72
Nexthop local: fe80::f8f5:cbff:fe74:cf72
BGP connection: non shared network
BGP Connect Retry Timer in Seconds: 120
Estimated round trip time: 3 ms
Read thread: on Write thread: on FD used: 28
BGP neighbor is 10.20.20.1, remote AS 65001, local AS 65001, internal link
Hostname: cloud2
BGP version 4, remote router ID 198.51.100.254, local router ID 192.168.2.1
AddPath:
Hostname Capability: advertised (name: vyos,domain name: n/a) received (name: cloud2,domain name: n/a)
none
R bit: False
Timers:
IPv4 Unicast:
F bit: False
Timers:
Message statistics:
Inq depth is 0
Outq depth is 0
Sent Rcvd
Opens: 1 1
Notifications: 0 0
Updates: 1 1
Keepalives: 50 50
Route Refresh: 0 0
Capability: 0 0
Total: 52 52
Update source is 10.20.20.254
0 accepted prefixes
Local host: 10.20.20.254, Local port: 40905
Foreign host: 10.20.20.1, Foreign port: 179
Nexthop: 10.20.20.254
Nexthop global: fe80::f50f:18ff:fe63:90a1
Nexthop local: fe80::f50f:18ff:fe63:90a1
Estimated round trip time: 1 ms
Read thread: on Write thread: on FD used: 31
Sorry, I donât get it. How should I do ?
Do you mean set default rout to each neighbor ?
vyos@vyos# set protocols static route 0.0.0.0/0 next-hop 10.10.10.1
vyos@vyos# set protocols static route 0.0.0.0/0 next-hop 10.20.20.1
Neighbours should export default routes
After this you receive/import such routes which will be placed in route table declared match route-map rule
Done!
but the route table is till empty.
S> 0.0.0.0/0 [1/0] via 10.10.10.1 (recursive), weight 1, 00:06:42
* via 10.10.10.1, wg01 onlink, weight 1, 00:06:42
via 10.20.20.1 (recursive), weight 1, 00:06:42
* via 10.20.20.1, wg02 onlink, weight 1, 00:06:42
S>* 10.10.10.0/24 [1/0] is directly connected, wg01, weight 1, 00:20:41
C>* 10.10.10.254/32 is directly connected, wg01, 00:20:41
S>* 10.20.20.0/24 [1/0] is directly connected, wg02, weight 1, 00:20:41
C>* 10.20.20.254/32 is directly connected, wg02, 00:20:42
C>* 100.64.0.0/30 is directly connected, eth0, 00:20:44
C>* 192.168.2.0/24 is directly connected, eth1, 00:20:45
S>* 198.51.100.254/32 [1/0] via 100.64.0.1, eth0, weight 1, 00:20:40
S>* 203.0.113.254/32 [1/0] via 100.64.0.1, eth0, weight 1, 00:20:40
my vyos config
vyos@vyos# run show configuration commands
set interfaces ethernet eth1 policy route 'PBR'
set protocols bgp 65001 neighbor 10.10.10.1 timers keepalive '10'
set protocols static route 198.51.100.254/32 next-hop 100.64.0.1
set protocols static route 203.0.113.254/32 next-hop 100.64.0.1
set service dhcp-server shared-network-name LAN-DHCP subnet 192.168.2.0/24 name-server '192.168.2.1'
set service dhcp-server shared-network-name LAN-DHCP subnet 192.168.2.0/24 range 0 stop '192.168.2.254'
set system login user vyos authentication encrypted-password '$6$p96vCymIVf.pAsYW$KWwo.AM/PF7psfABBHWwAeryXwB0YE74Ns/wK6VhKf0OtKpWgejYK'
