I config nat rule on vyos, use dperf (a DPDK network performance tools) to test performance.
I want to see how many session on the vyos when I test.
Is voys have show like juniper show security flow sessions
These operational commands will show you the active destination/source NAT translations:
vyos@vyos:~$ show nat destination translations
Possible completions:
<Enter> Execute the current command
address Show active NAT destination translations for an IP address
detail Show active destination NAT translations detail
For source nat rule, use “show nat source translations
” , and there are other commands as well: show nat destination/source statistics
I keep the session is 50k (dperf show), use the show nat destination translations
, cpu use will be 99%
it have any other low power commands to get approximate data ?
Maybe sudo conntrack -C
will help?
