Romell
1
Please I really need your help,
If I want to copy a key that I’m using for an Openvpn from router vyos 1 with this IP 192.168.0.249
the destination of the file is /config/auth/TEST
TEST is the name of the key
I want to use SCP to copy this key from vyos@192.168.0.249 to vyos@192.168.0.254
How I can do it on a vyos router and also cmd ?
Best Regards
vyos can use scp, but I don’t know if it can meet your requirements
From node 192.168.0.249
sudo scp /config/auth/TEST vyos@192.168.0.254:/config/auth/
Romell
4
Ok so on my vyos machine I can use this command ?
Yes, you can use this command
system
Closed
6
