I want to give back some work that I have done with vyos in the hope
someone else can be enlighted as I was during the discovery of this
exciting universe.
First of all what is my goal: I want to start a tiny router as a sandboxed
virtualized environment using only the own compiled ISO image, the footprint
of approx. 220MB is adequate. Boot time is a couple of seconds, configuration
time is quicker than boot time. It means using the live CD give me enough degree
of flexibility to make everything what i want to do (NATting & Firewalling)
A reader could ask, why do you not install the router image on a partition
and use the much simpler read-write environment?
It is a matter of security, the system lives in memory. It has a defined
set of functionality no more else.
The prerequisite to use such a system are the following:
- Knowledge how to build the iso image WITH open-vm-tools (See my other howto)
- Knowledge of VMware and how to build an OVF image with OVF environment vars
- Knowledge of XML and XSLT handling how to extract key value pairs from the
XML document - Knowledge of linux boot/init procedures and how to hook into it
- Knowledge of bash/vbash how to execute and configure the router from a script
- Knowledge of SQL if you are using sqlite3 as a file oriented RDBMS
It is a lot and frankly speeking you need a little more of other tips and tricks.
I cannot explain everything in it’s entirety, it’s only a recipe just to give you and idea how I have solved this.
- Include sqlite3 from debian squeezy if you’re going to use sqlite3 for
keystore management, it is not required, you can use the normal configuration
file. It is up to you. - Open (/build-iso/livecd/templates/community/config.boot.default) and
preconfigure the router with some static variables like time server, DNS
server, users & password, change the hostname, set ssh service & port for
dynamic reconfiguration after instanciation - Go to (/build-iso/livecd/config.vyatta/chroot_local-includes) and create
the etc directory - Copy the /etc/rc.local file into the newly created etc directory
- Open the rc.local file and Insert after
# By default this script does nothing.
# set keyboad to german
sudo loadkeys /usr/share/keymaps/i386/qwertz/de.kmap.gz
# initialize router
/usr/local/bin/initRouter
- Build the IS0 WITH open-vm-tools (we need a working vmtoolsd environment)
- Define an empty VMware image with 512 vRAM
- Mount the ISO and dont forget to enable connection at startup
- Go into the option tab and check the next BOOT into BIOS to change the
boot order after the next reboot (CD-ROM 1st, HDD after) - Define the network in which this router will work (e.g. “VM_Network”)
- Select the VMware image and click on “Edit settings”
- Now it’s time to go into the VMware vSphere Console and insert some
OVF key value pairs - Go to the “Options” tab and enable the “vAPP options”
- Now go to the “OVF settings” and check “Vmware Tools” under “OVF Environment Transport” (important!)
- Go to Advanced tab and click on “Properties” on the right
- Create at least three keys value pairs: “gateway, router ipaddress, network mask”
Key Label Type Value
EGW0 EGW0 ip 10.0.1.1
EIP0 EIP0 ip 10.0.1.100
ENM0 ENM0 ip 255.255.255.0
- Now it’s time to build the glue code inside /build-iso/livecd/config.vyatta/chroot_local-includes/usr/local/bin/usr/local/bin/initRouter.
Sorry I can only outline the steps. It’s to much code to publish here.
- you need some tools from /usr/bin directory like vmtoolsd, ipcalc, xsltproc
- with /usr/bin/vmtoolsd --cmd ‘info-get guestinfo.ovfEnv’ > /config/config.xml
you generate the XML file at boot time like
<?xml version="1.0" encoding="UTF-8"?>
<Environment
xmlns="http://schemas.dmtf.org/ovf/environment/1"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:oe="http://schemas.dmtf.org/ovf/environment/1"
xmlns:ve="http://www.vmware.com/schema/ovfenv"
oe:id=""
ve:vCenterId="vm-80602">
<PlatformSection>
<Kind>VMware ESXi</Kind>
<Version>5.0.0</Version>
<Vendor>VMware, Inc.</Vendor>
<Locale>de</Locale>
</PlatformSection>
<PropertySection>
<Property oe:key="EGW0" oe:value="10.0.1.1"/>
<Property oe:key="EIP0" oe:value="10.0.1.100"/>
<Property oe:key="ENM0" oe:value="255.255.255.0"/>
</PropertySection>
<ve:EthernetAdapterSection>
<ve:Adapter ve:mac="00:50:56:93:37:44" ve:network="VM_Network" ve:unitNumber="7"/>
</ve:EthernetAdapterSection>
</Environment>
- with an inline code you can extract later the key value pairs with xsltproc.
Store this code under /config/config.xsl:
cat > ${_OVF_XSL_FILE} << 'EOF'
<xsl:stylesheet version="1.0"
xmlns:xsl="http://www.w3.org/1999/XSL/Transform"
xmlns:oe="http://schemas.dmtf.org/ovf/environment/1">
<xsl:output method="text" indent="no"/>
<xsl:template match="/">
<xsl:for-each select="oe:Environment/oe:PropertySection/oe:Property">
<xsl:text></xsl:text>
<xsl:value-of select="@oe:key"/>
<xsl:text>|</xsl:text>
<xsl:value-of select="@oe:value"/>
<xsl:text>
</xsl:text>
</xsl:for-each>
</xsl:template>
</xsl:stylesheet>
EOF
- Execute /usr/bin/xsltproc /config/config.xsl /config/config.xml > /config/config.cfg
and the key value pairs looks like:
EGW0|10.0.1.1
EIP0|10.0.1.100
ENM0|255.255.255.0
- Now you are able to use some bash code to get the key and the appropriate value or put it into an sqlite3 file database
- create a database config.db in /config with:
sqlite3 /config/config.db "create table OVF_KEY_TABLE (KEY TEXT PRIMARY KEY, VALUE TEXT);"
- import /config/config.cfg into /config/config.db with:
sqlite3 /config/config.db ".import /config/config.cfg OVF_KEY_TABLE";
- Now you’re able to go with SQL or plain-file. SQL can be useful if combined with a RESTful/JSON and
sqlite3 PHP module inside lighttpd for lifecycle management. This is another story, may be on another HowTo - It is time now to inject this into the router /usr/local/bin/initRouter script using the vyatta command wrapper opt/vyatta/sbin/vyatta-cfg-cmd-wrapper
- here roughly a template, feel free to add every thing you like and give
me feedback if you find any trick or a better solution for this.
NOTE: I use /usr/bin/ipcalc to generate the prefix from the network mask inside my function getOVF_CFGvalPF
#!/bin/vbash
opt/vyatta/sbin/vyatta-cfg-cmd-wrapper begin
opt/vyatta/sbin/vyatta-cfg-cmd-wrapper set interfaces ethernet eth0 address $(getOVF_CFGvalue ${OVF_CFG_FILE} EIP0)/$(getOVF_CFGvalPF ${OVF_CFG_FILE} EPF0)
opt/vyatta/sbin/vyatta-cfg-cmd-wrapper set system gateway-address $(getOVF_CFGvalue ${OVF_CFG_FILE} EGW0)
opt/vyatta/sbin/vyatta-cfg-cmd-wrapper commit
opt/vyatta/sbin/vyatta-cfg-cmd-wrapper save
opt/vyatta/sbin/vyatta-cfg-cmd-wrapper end
- Add more code for stability and security like CHECK/BUILD sum
- Add more code for router live cycle management (Search, Create, Read, Update, Delete)
- Put the initRouter script under /build-iso/livecd/config.vyatta/chroot_local-includes/usr/local/bin
- Rebuild ISO
- Test it
I know it is only a recipe, of course we can exchange any suggestion or
thoughts you might have on this topic.
NOTE: At this point you can ask why is there no persistence layer? There is a bug deep inside the debian live environment,
I am currently trying to find the bug. It is hard, I want to format a tiny ext2 /dev/sda1 partition (10MB)
as /config and unionfs/aufs mount it rw to the ISO.
I tried to boot isolinux with persistent flag set,
currently this is not working as expected.
Stay tuned I hope to fix this or you can help me on this
