Installation of VyOS in GNS3
#1
I’ve created a blog post, which shows the installation of VyOS 1.2 beta in GNS3 , see http://www.bernhard-ehlers.de/blog/2017/09/17/gns3-create-vyos-vm.html
#2
Thanks for sharing!
Let me know if we can add this to wiki.
#3
Sure, you can use it freely. I’m glad, when I can help.
#4
Some kind soul has added this to the VyOS wiki, see https://wiki.vyos.net/wiki/VyOS_on_GNS3
But there is one issue, I’don’t know how to handle:
gns3.com has a special understanding of hyperlinks. In the “Terms of Use” at the bottom of www.gns3.com/community they define their view of acceptable links. In short, only links to www.gns3.com should be made and even these have to be registered by mailing them. I have once asked them, if they are serious about that, but got no answer. Therefore I’m not sure, if the wiki should use links to GNS3.
#5
Yes,
i asked guys to add this,
i will be checking about gns3, we don’t have issues to link them
