One 10 gig card in my box is marked A/D for State and Link. My config does not have “disable” set any idea why both ports would show down? On another box with the same model card my unused interfaces show u/D not A/D.
Please describe the VyOS version you are using. If running VyOS 1.3-rolling please update to the latest release as there was an error in the show interfaces
command for link down vs admin down.
Ah, I am using rolling. Will try an upgrade
