I am using 1.3.0-rc1 and trying to setup an IPoE server:
set service ipoe-server authentication interface eth2 mac-address 00:AA:00:00:00:00
set service ipoe-server authentication mode 'local'
set service ipoe-server name-server '1.1.1.1'
set service ipoe-server name-server '2606:4700:4700::1111'
set service ipoe-server interface eth2 client-subnet '100.64.0.0/24'
set service ipoe-server client-ipv6-pool delegate '2001:db8:1::/48' delegation-prefix '56'
set service ipoe-server client-ipv6-pool prefix '2001:db8:2::/48' mask '64'
it works perfectly with IPv4, but the IPv6 PD or WAN (/64) is never assigned. What i am missing ?
Yes, i am aware of that, however it doesn’t receive an IPv6 WAN or PD on the interface.
I mean, if i execute a DHCP client ($ sudo dhclient ethN) in linux it gets the IPv4, and after that i run an dhclient -6 ethN on the same interface it still doesn’t get any IP or response.
Hello @marcomuskus, really a very odd situation. IPoE daemon can not send the packet, because there is no link-local address on the interface ipoeX. Could you try manually add LL and run dhclient -6 again
sudo ip addr add fe80::5200:ff:fe0d:1/64 dev ipoe0
