Is it normal to see warnings and errors during VyOS build
This is probably a stupid question, but is it normal to see warnings and errors during the VyOS build? Couldn’t find any other posts mentioning it.
Build process as follows
git clone -b sagitta --single-branch https://github.com/vyos/vyos-build
cd vyos-build
sudo docker build -t vyos/vyos-build:sagitta docker
sudo docker run --rm -it --privileged  -v $(pwd):/vyos vyos/vyos-build:sagitta bash
inside container
sudo ./build-vyos-image iso --architecture amd64
During build I get following in no particular order as some of them are reoccurring.
Warnings
dpkg-divert: warning: diverting file <SOMEFILE> from an Essential package with rename is dangerous, use --no-rename
dpkg-divert: warning: please specify --no-rename explicitly
dpkg-statoverride: warning: --update given but /var/log/chrony does not exist
cme: warning: cannot determine CC system type, falling back to default (native compilation)
Unit /lib/systemd/system/vyos-hostsd.service is added as a dependency to a non-existent unit cloud-init-local.service.
Errors
dpkg-divert: error: mismatch on package
Failed to disable unit, unit logd.service does not exist
Failed to disable unit, unit heartbeat.service does not exist.
Failed to disable unit, unit vpp.service does not exist.
Although it does spit out Build completed successfully right at the end :slight_smile:
One thing I did notice this time is that under the build directory I used to have an image called vyos-1.4-rolling-date-amd.iso but for some reason I have vyos-999.date-amd64.iso
Regards
