Hi @zsdc,
gateway adress is reachable, thats the issue. I will provide all info requsted by you below but let’s check availability first:
vyos@vyos# ping 172.31.1.1
PING 172.31.1.1 (172.31.1.1) 56(84) bytes of data.
64 bytes from 172.31.1.1: icmp_seq=1 ttl=64 time=0.185 ms
ok, it works. Now let’s try to add a static route via vbash:
vyos@vyos# set protocols static route 1.1.1.1/32 next-hop 172.31.1.1
vyos@vyos# commit
vyos@vyos# ip ro
default via 172.31.1.1 dev eth0 proto static metric 20 onlink
1.1.1.1 via 172.31.1.1 dev eth0 proto static metric 20 onlink
10.0.0.0/16 via 10.0.0.1 dev eth1 proto static metric 20 onlink
vyos@vyos# ping 1.1.1.1
PING 1.1.1.1 (1.1.1.1) 56(84) bytes of data.
64 bytes from 1.1.1.1: icmp_seq=1 ttl=57 time=20.4 ms
Looks ok. Now I delete static route (delete protocols static) and let’s try to add same but as kernel route:
vyos@vyos:~$ ip ro
vyos@vyos:~$ sudo ip ro add 1.1.1.1 via 172.31.1.1 dev eth0
Error: Nexthop has invalid gateway.
vyos@vyos:~$
Now about your questions:
Are DHCP servers controlled by yourself, or this deployment is somewhere in the cloud or any other uncontrolled place?
VyOS is deployed in Hetzner VPS (not a bare metal). DHCP is controlled by Hetzner.
Also, can you please share the output of a bit different command, so we can see detailed DHCP logs: sudo journalctl -b | grep dhc
( dhc
without “p” at the end)?
Here it is:
vyos@vyos:~$ sudo journalctl -b | grep dhc
Aug 16 04:04:48 debian vyos-hostsd[599]: Request data: {"type": "name_server_tags_system", "op": "add", "data": ["dhcp-eth0", "dhcpv6-eth0"]}
Aug 16 04:04:48 debian vyos-hostsd[599]: Request data: {"type": "name_server_tags_system", "op": "add", "data": ["dhcp-eth1", "dhcpv6-eth1"]}
Aug 16 04:04:51 vyos sudo[1553]: root : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/usr/bin/systemctl restart dhclient@eth1.service
Aug 16 04:04:51 vyos systemd[1]: Created slice system-dhclient.slice.
Aug 16 04:04:52 vyos dhclient-script-vyos[1567]: Current dhclient PID: 1560, Parent PID: 1555, IP version: -4, All dhclients for interface eth1: 1555 1560
Aug 16 04:04:52 vyos dhclient-script-vyos[1567]: Passing command to /usr/sbin/ip: "link set dev eth1 up"
Aug 16 04:04:52 vyos dhclient-script-vyos[1567]: No changes to apply via vyos-hostsd-client
Aug 16 04:04:52 vyos dhclient[1560]: DHCPDISCOVER on eth1 to 255.255.255.255 port 67 interval 6
Aug 16 04:04:52 vyos dhclient[1560]: DHCPOFFER of 10.0.0.3 from 10.0.0.1
Aug 16 04:04:52 vyos dhclient[1560]: DHCPREQUEST for 10.0.0.3 on eth1 to 255.255.255.255 port 67
Aug 16 04:04:52 vyos dhclient[1560]: DHCPACK of 10.0.0.3 from 10.0.0.1
Aug 16 04:04:52 vyos dhclient-script-vyos[1596]: Current dhclient PID: 1560, Parent PID: 1, IP version: -4, All dhclients for interface eth1: 1560
Aug 16 04:04:52 vyos dhclient-script-vyos[1596]: Passing command to /usr/sbin/ip: "-4 addr add 10.0.0.3/255.255.255.255 broadcast 10.0.0.3 valid_lft 86400 preferred_lft 86400 dev eth1 label eth1"
Aug 16 04:04:52 vyos dhclient-script-vyos[1596]: Passing command to /usr/sbin/ip: "link set dev eth1 mtu 1450"
Aug 16 04:04:52 vyos dhclient-script-vyos[1596]: No changes to apply via vyos-hostsd-client
Aug 16 04:04:52 vyos dhclient-script-vyos[1596]: FRR status: running
Aug 16 04:04:52 vyos dhclient-script-vyos[1596]: Checking if the route presented in kernel: 10.0.0.1/32 dev eth1
Aug 16 04:04:52 vyos dhclient-script-vyos[1596]: Converted vtysh command: "ip route 10.0.0.1/32 eth1 tag 210 210 "
Aug 16 04:04:52 vyos dhclient-script-vyos[1596]: Sending command to vtysh
Aug 16 04:04:52 vyos dhclient-script-vyos[1596]: Checking if the route presented in kernel: 10.0.0.0/16 via 10.0.0.1 dev eth1
Aug 16 04:04:52 vyos dhclient-script-vyos[1596]: Converted vtysh command: "ip route 10.0.0.0/16 10.0.0.1 eth1 tag 210 210 "
Aug 16 04:04:52 vyos sudo[1681]: root : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/usr/bin/systemctl restart dhclient@eth0.service
Aug 16 04:04:52 vyos dhclient-script-vyos[1686]: Current dhclient PID: 1685, Parent PID: 1683, IP version: -4, All dhclients for interface eth0: 1683 1685
Aug 16 04:04:52 vyos dhclient[1560]: bound to 10.0.0.3 -- renewal in 41300 seconds.
Aug 16 04:04:52 vyos dhclient-script-vyos[1686]: Passing command to /usr/sbin/ip: "link set dev eth0 up"
Aug 16 04:04:52 vyos dhclient-script-vyos[1686]: No changes to apply via vyos-hostsd-client
Aug 16 04:04:52 vyos dhclient[1685]: DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 6
Aug 16 04:04:52 vyos dhclient[1685]: DHCPOFFER of 95.216.215.168 from 172.31.1.1
Aug 16 04:04:52 vyos dhclient[1685]: DHCPREQUEST for 95.216.215.168 on eth0 to 255.255.255.255 port 67
Aug 16 04:04:52 vyos dhclient[1685]: DHCPACK of 95.216.215.168 from 172.31.1.1
Aug 16 04:04:52 vyos dhclient-script-vyos[1721]: Current dhclient PID: 1685, Parent PID: 1, IP version: -4, All dhclients for interface eth0: 1685
Aug 16 04:04:52 vyos dhclient-script-vyos[1721]: Passing command to /usr/sbin/ip: "-4 addr add 95.216.215.168/255.255.255.255 broadcast 95.216.215.168 valid_lft 86400 preferred_lft 86400 dev eth0 label eth0"
Aug 16 04:04:52 vyos dhclient-script-vyos[1721]: Deleting nameservers with tag "dhcp-eth0" via vyos-hostsd-client
Aug 16 04:04:52 vyos vyos-hostsd[599]: Request data: {"type": "name_servers", "op": "delete", "data": ["dhcp-eth0"]}
Aug 16 04:04:52 vyos dhclient-script-vyos[1721]: Adding nameservers "213.133.99.99 213.133.100.100 213.133.98.98" with tag "dhcp-eth0" via vyos-hostsd-client
Aug 16 04:04:52 vyos vyos-hostsd[599]: Request data: {"type": "name_servers", "op": "add", "data": {"dhcp-eth0": ["213.133.99.99", "213.133.100.100", "213.133.98.98"]}}
Aug 16 04:04:52 vyos dhclient-script-vyos[1721]: Applying changes via vyos-hostsd-client
Aug 16 04:04:53 vyos dhclient-script-vyos[1721]: No changes to apply via vyos-hostsd-client
Aug 16 04:04:53 vyos dhclient-script-vyos[1721]: FRR status: running
Aug 16 04:04:53 vyos dhclient-script-vyos[1721]: Checking if the route presented in kernel: 172.31.1.1/32 dev eth0
Aug 16 04:04:53 vyos dhclient-script-vyos[1721]: Converted vtysh command: "ip route 172.31.1.1/32 eth0 tag 210 210 "
Aug 16 04:04:53 vyos dhclient-script-vyos[1721]: Sending command to vtysh
Aug 16 04:04:53 vyos dhclient-script-vyos[1721]: Checking if the route presented in kernel: 0.0.0.0/0 via 172.31.1.1 dev eth0
Aug 16 04:04:53 vyos dhclient-script-vyos[1721]: Converted vtysh command: "ip route 0.0.0.0/0 172.31.1.1 eth0 tag 210 210 "
Aug 16 04:04:53 vyos vyos-hostsd[599]: Sent response: {'data': ['system', 'dhcp-eth0', 'dhcpv6-eth0', 'dhcp-eth1', 'dhcpv6-eth1']}
Aug 16 04:04:53 vyos vyos-hostsd[599]: Request data: {"type": "name_server_tags_system", "op": "delete", "data": ["system", "dhcp-eth0", "dhcpv6-eth0", "dhcp-eth1", "dhcpv6-eth1"]}
Aug 16 04:04:53 vyos vyos-hostsd[599]: Request data: {"type": "name_server_tags_system", "op": "add", "data": ["dhcp-eth0", "dhcpv6-eth0"]}
Aug 16 04:04:53 vyos vyos-hostsd[599]: Request data: {"type": "name_server_tags_system", "op": "add", "data": ["dhcp-eth1", "dhcpv6-eth1"]}
Aug 16 04:04:53 vyos dhclient[1685]: bound to 95.216.215.168 -- renewal in 39513 seconds.
Aug 16 04:04:54 vyos vyos-hostsd[599]: Sent response: {'data': ['system', 'dhcp-eth0', 'dhcpv6-eth0', 'dhcp-eth1', 'dhcpv6-eth1']}
Aug 16 04:04:54 vyos vyos-hostsd[599]: Request data: {"type": "name_server_tags_system", "op": "delete", "data": ["system", "dhcp-eth0", "dhcpv6-eth0", "dhcp-eth1", "dhcpv6-eth1"]}
Aug 16 04:04:54 vyos vyos-hostsd[599]: Request data: {"type": "name_server_tags_system", "op": "add", "data": ["dhcp-eth0", "dhcpv6-eth0"]}
Aug 16 04:04:54 vyos vyos-hostsd[599]: Request data: {"type": "name_server_tags_system", "op": "add", "data": ["dhcp-eth1", "dhcpv6-eth1"]}
Aug 16 15:03:26 vyos dhclient[1685]: DHCPREQUEST for 95.216.215.168 on eth0 to 172.31.1.1 port 67
Aug 16 15:03:26 vyos dhclient[1685]: DHCPACK of 95.216.215.168 from 172.31.1.1
Aug 16 15:03:26 vyos dhclient-script-vyos[6728]: Current dhclient PID: 1685, Parent PID: 1, IP version: -4, All dhclients for interface eth0: 1685
Aug 16 15:03:26 vyos dhclient-script-vyos[6728]: Passing command to /usr/sbin/ip: "-4 addr change 95.216.215.168/255.255.255.255 broadcast 95.216.215.168 valid_lft 86400 preferred_lft 86400 dev eth0 label eth0"
Aug 16 15:03:26 vyos dhclient-script-vyos[6728]: Deleting nameservers with tag "dhcp-eth0" via vyos-hostsd-client
Aug 16 15:03:26 vyos vyos-hostsd[599]: Request data: {"type": "name_servers", "op": "delete", "data": ["dhcp-eth0"]}
Aug 16 15:03:26 vyos dhclient-script-vyos[6728]: Adding nameservers "213.133.99.99 213.133.100.100 213.133.98.98" with tag "dhcp-eth0" via vyos-hostsd-client
Aug 16 15:03:26 vyos vyos-hostsd[599]: Request data: {"type": "name_servers", "op": "add", "data": {"dhcp-eth0": ["213.133.99.99", "213.133.100.100", "213.133.98.98"]}}
Aug 16 15:03:26 vyos dhclient-script-vyos[6728]: Applying changes via vyos-hostsd-client
Aug 16 15:03:26 vyos dhclient-script-vyos[6728]: No changes to apply via vyos-hostsd-client
Aug 16 15:03:26 vyos dhclient[1685]: bound to 95.216.215.168 -- renewal in 35067 seconds.
Aug 16 15:33:12 vyos dhclient[1560]: DHCPREQUEST for 10.0.0.3 on eth1 to 10.0.0.1 port 67
Aug 16 15:33:12 vyos dhclient[1560]: DHCPACK of 10.0.0.3 from 10.0.0.1
Aug 16 15:33:12 vyos dhclient-script-vyos[6775]: Current dhclient PID: 1560, Parent PID: 1, IP version: -4, All dhclients for interface eth1: 1560
Aug 16 15:33:12 vyos dhclient-script-vyos[6775]: Replacing MTU value for eth1 with preconfigured one: 1450
Aug 16 15:33:12 vyos dhclient-script-vyos[6775]: Passing command to /usr/sbin/ip: "-4 addr change 10.0.0.3/255.255.255.255 broadcast 10.0.0.3 valid_lft 86400 preferred_lft 86400 dev eth1 label eth1"
Aug 16 15:33:12 vyos dhclient-script-vyos[6775]: No changes to apply via vyos-hostsd-client
Aug 16 15:33:12 vyos dhclient[1560]: bound to 10.0.0.3 -- renewal in 40099 seconds.
Aug 17 00:47:53 vyos dhclient[1685]: DHCPREQUEST for 95.216.215.168 on eth0 to 172.31.1.1 port 67
Aug 17 00:47:53 vyos dhclient[1685]: DHCPACK of 95.216.215.168 from 172.31.1.1
Aug 17 00:47:53 vyos dhclient-script-vyos[8349]: Current dhclient PID: 1685, Parent PID: 1, IP version: -4, All dhclients for interface eth0: 1685
Aug 17 00:47:53 vyos dhclient-script-vyos[8349]: Passing command to /usr/sbin/ip: "-4 addr change 95.216.215.168/255.255.255.255 broadcast 95.216.215.168 valid_lft 86400 preferred_lft 86400 dev eth0 label eth0"
Aug 17 00:47:53 vyos dhclient-script-vyos[8349]: Deleting nameservers with tag "dhcp-eth0" via vyos-hostsd-client
Aug 17 00:47:53 vyos vyos-hostsd[599]: Request data: {"type": "name_servers", "op": "delete", "data": ["dhcp-eth0"]}
Aug 17 00:47:53 vyos dhclient-script-vyos[8349]: Adding nameservers "213.133.99.99 213.133.100.100 213.133.98.98" with tag "dhcp-eth0" via vyos-hostsd-client
Aug 17 00:47:53 vyos vyos-hostsd[599]: Request data: {"type": "name_servers", "op": "add", "data": {"dhcp-eth0": ["213.133.99.99", "213.133.100.100", "213.133.98.98"]}}
Aug 17 00:47:53 vyos dhclient-script-vyos[8349]: Applying changes via vyos-hostsd-client
Aug 17 00:47:53 vyos dhclient-script-vyos[8349]: No changes to apply via vyos-hostsd-client
Aug 17 00:47:53 vyos dhclient[1685]: bound to 95.216.215.168 -- renewal in 38544 seconds.
Aug 17 02:41:31 vyos dhclient[1560]: DHCPREQUEST for 10.0.0.3 on eth1 to 10.0.0.1 port 67
Aug 17 02:41:31 vyos dhclient[1560]: DHCPACK of 10.0.0.3 from 10.0.0.1
Aug 17 02:41:31 vyos dhclient-script-vyos[8426]: Current dhclient PID: 1560, Parent PID: 1, IP version: -4, All dhclients for interface eth1: 1560
Aug 17 02:41:31 vyos dhclient-script-vyos[8426]: Replacing MTU value for eth1 with preconfigured one: 1450
Aug 17 02:41:31 vyos dhclient-script-vyos[8426]: Passing command to /usr/sbin/ip: "-4 addr change 10.0.0.3/255.255.255.255 broadcast 10.0.0.3 valid_lft 86400 preferred_lft 86400 dev eth1 label eth1"
Aug 17 02:41:31 vyos dhclient-script-vyos[8426]: No changes to apply via vyos-hostsd-client
Aug 17 02:41:31 vyos dhclient[1560]: bound to 10.0.0.3 -- renewal in 40527 seconds.
Aug 17 11:30:17 vyos dhclient[1685]: DHCPREQUEST for 95.216.215.168 on eth0 to 172.31.1.1 port 67
Aug 17 11:30:17 vyos dhclient[1685]: DHCPACK of 95.216.215.168 from 172.31.1.1
Aug 17 11:30:17 vyos dhclient-script-vyos[8709]: Current dhclient PID: 1685, Parent PID: 1, IP version: -4, All dhclients for interface eth0: 1685
Aug 17 11:30:17 vyos dhclient-script-vyos[8709]: Passing command to /usr/sbin/ip: "-4 addr change 95.216.215.168/255.255.255.255 broadcast 95.216.215.168 valid_lft 86400 preferred_lft 86400 dev eth0 label eth0"
Aug 17 11:30:18 vyos dhclient-script-vyos[8709]: Deleting nameservers with tag "dhcp-eth0" via vyos-hostsd-client
Aug 17 11:30:18 vyos vyos-hostsd[599]: Request data: {"type": "name_servers", "op": "delete", "data": ["dhcp-eth0"]}
Aug 17 11:30:18 vyos dhclient-script-vyos[8709]: Adding nameservers "213.133.99.99 213.133.100.100 213.133.98.98" with tag "dhcp-eth0" via vyos-hostsd-client
Aug 17 11:30:18 vyos vyos-hostsd[599]: Request data: {"type": "name_servers", "op": "add", "data": {"dhcp-eth0": ["213.133.99.99", "213.133.100.100", "213.133.98.98"]}}
Aug 17 11:30:18 vyos dhclient-script-vyos[8709]: Applying changes via vyos-hostsd-client
Aug 17 11:30:18 vyos dhclient-script-vyos[8709]: No changes to apply via vyos-hostsd-client
Aug 17 11:30:18 vyos dhclient[1685]: bound to 95.216.215.168 -- renewal in 36653 seconds.
Aug 17 13:56:58 vyos dhclient[1560]: DHCPREQUEST for 10.0.0.3 on eth1 to 10.0.0.1 port 67
Aug 17 13:56:58 vyos dhclient[1560]: DHCPACK of 10.0.0.3 from 10.0.0.1
Aug 17 13:56:58 vyos dhclient-script-vyos[8796]: Current dhclient PID: 1560, Parent PID: 1, IP version: -4, All dhclients for interface eth1: 1560
Aug 17 13:56:58 vyos dhclient-script-vyos[8796]: Replacing MTU value for eth1 with preconfigured one: 1450
Aug 17 13:56:58 vyos dhclient-script-vyos[8796]: Passing command to /usr/sbin/ip: "-4 addr change 10.0.0.3/255.255.255.255 broadcast 10.0.0.3 valid_lft 86400 preferred_lft 86400 dev eth1 label eth1"
Aug 17 13:56:58 vyos dhclient-script-vyos[8796]: No changes to apply via vyos-hostsd-client
Aug 17 13:56:58 vyos dhclient[1560]: bound to 10.0.0.3 -- renewal in 33853 seconds.
Aug 17 21:41:11 vyos dhclient[1685]: DHCPREQUEST for 95.216.215.168 on eth0 to 172.31.1.1 port 67
Aug 17 21:41:11 vyos dhclient[1685]: DHCPACK of 95.216.215.168 from 172.31.1.1
Aug 17 21:41:11 vyos dhclient-script-vyos[8995]: Current dhclient PID: 1685, Parent PID: 1, IP version: -4, All dhclients for interface eth0: 1685
Aug 17 21:41:11 vyos dhclient-script-vyos[8995]: Passing command to /usr/sbin/ip: "-4 addr change 95.216.215.168/255.255.255.255 broadcast 95.216.215.168 valid_lft 86400 preferred_lft 86400 dev eth0 label eth0"
Aug 17 21:41:11 vyos dhclient-script-vyos[8995]: Deleting nameservers with tag "dhcp-eth0" via vyos-hostsd-client
Aug 17 21:41:11 vyos vyos-hostsd[599]: Request data: {"type": "name_servers", "op": "delete", "data": ["dhcp-eth0"]}
Aug 17 21:41:11 vyos dhclient-script-vyos[8995]: Adding nameservers "213.133.99.99 213.133.100.100 213.133.98.98" with tag "dhcp-eth0" via vyos-hostsd-client
Aug 17 21:41:11 vyos vyos-hostsd[599]: Request data: {"type": "name_servers", "op": "add", "data": {"dhcp-eth0": ["213.133.99.99", "213.133.100.100", "213.133.98.98"]}}
Aug 17 21:41:11 vyos dhclient-script-vyos[8995]: Applying changes via vyos-hostsd-client
Aug 17 21:41:11 vyos dhclient-script-vyos[8995]: No changes to apply via vyos-hostsd-client
Aug 17 21:41:11 vyos dhclient[1685]: bound to 95.216.215.168 -- renewal in 33749 seconds.
Aug 17 23:21:11 vyos dhclient[1560]: DHCPREQUEST for 10.0.0.3 on eth1 to 10.0.0.1 port 67
Aug 17 23:21:11 vyos dhclient[1560]: DHCPACK of 10.0.0.3 from 10.0.0.1
Aug 17 23:21:11 vyos dhclient-script-vyos[9517]: Current dhclient PID: 1560, Parent PID: 1, IP version: -4, All dhclients for interface eth1: 1560
Aug 17 23:21:11 vyos dhclient-script-vyos[9517]: Replacing MTU value for eth1 with preconfigured one: 1450
Aug 17 23:21:11 vyos dhclient-script-vyos[9517]: Passing command to /usr/sbin/ip: "-4 addr change 10.0.0.3/255.255.255.255 broadcast 10.0.0.3 valid_lft 86400 preferred_lft 86400 dev eth1 label eth1"
Aug 17 23:21:11 vyos dhclient-script-vyos[9517]: No changes to apply via vyos-hostsd-client
Aug 17 23:21:11 vyos dhclient[1560]: bound to 10.0.0.3 -- renewal in 36384 seconds.
Aug 18 07:03:40 vyos dhclient[1685]: DHCPREQUEST for 95.216.215.168 on eth0 to 172.31.1.1 port 67
Aug 18 07:03:40 vyos dhclient[1685]: DHCPACK of 95.216.215.168 from 172.31.1.1
Aug 18 07:03:40 vyos dhclient-script-vyos[9801]: Current dhclient PID: 1685, Parent PID: 1, IP version: -4, All dhclients for interface eth0: 1685
Aug 18 07:03:40 vyos dhclient-script-vyos[9801]: Passing command to /usr/sbin/ip: "-4 addr change 95.216.215.168/255.255.255.255 broadcast 95.216.215.168 valid_lft 86400 preferred_lft 86400 dev eth0 label eth0"
Aug 18 07:03:40 vyos dhclient-script-vyos[9801]: Deleting nameservers with tag "dhcp-eth0" via vyos-hostsd-client
Aug 18 07:03:40 vyos vyos-hostsd[599]: Request data: {"type": "name_servers", "op": "delete", "data": ["dhcp-eth0"]}
Aug 18 07:03:40 vyos dhclient-script-vyos[9801]: Adding nameservers "213.133.99.99 213.133.100.100 213.133.98.98" with tag "dhcp-eth0" via vyos-hostsd-client
Aug 18 07:03:40 vyos vyos-hostsd[599]: Request data: {"type": "name_servers", "op": "add", "data": {"dhcp-eth0": ["213.133.99.99", "213.133.100.100", "213.133.98.98"]}}
Aug 18 07:03:40 vyos dhclient-script-vyos[9801]: Applying changes via vyos-hostsd-client
Aug 18 07:03:40 vyos dhclient-script-vyos[9801]: No changes to apply via vyos-hostsd-client
Aug 18 07:03:40 vyos dhclient[1685]: bound to 95.216.215.168 -- renewal in 39722 seconds.
Aug 18 09:27:35 vyos dhclient[1560]: DHCPREQUEST for 10.0.0.3 on eth1 to 10.0.0.1 port 67
Aug 18 09:27:35 vyos dhclient[1560]: DHCPACK of 10.0.0.3 from 10.0.0.1
Aug 18 09:27:35 vyos dhclient-script-vyos[9890]: Current dhclient PID: 1560, Parent PID: 1, IP version: -4, All dhclients for interface eth1: 1560
Aug 18 09:27:36 vyos dhclient-script-vyos[9890]: Replacing MTU value for eth1 with preconfigured one: 1450
Aug 18 09:27:36 vyos dhclient-script-vyos[9890]: Passing command to /usr/sbin/ip: "-4 addr change 10.0.0.3/255.255.255.255 broadcast 10.0.0.3 valid_lft 86400 preferred_lft 86400 dev eth1 label eth1"
Aug 18 09:27:36 vyos dhclient-script-vyos[9890]: No changes to apply via vyos-hostsd-client
Aug 18 09:27:36 vyos dhclient[1560]: bound to 10.0.0.3 -- renewal in 39395 seconds.
vyos@vyos:~$
