We are using nftables as firewall in vyos, and we’d like to know if it’s possible to keep it enable across system updates.
thx
thx
Hello!
Technically, all that is located inside the /config/
folder will be kept during an update. If you are able to put all necessary data there (for an example: package and some check-script, which will be invoked via vyos-postconfig-bootup.script), this should work.
