I have migrated from mikrotik to VyOS. In mikrotik I could provide certain sites a /30 as ip address. I have two other mikrotiks(not mine) connecting to the VyOS router. Earlier in mikrotik i would have created a username and manually mentioned the remote ip address and local ip address for that l2tp client. Is it possible to do the same with VyOS? On that /30 I run ospf.
in case of the other end being mikrotik will it work? There is no oprtion for setting tunnel id in mikrotik.
