I’ve been running 1.1.8 for quite some time and decided to “upgrade” a router and test out the latest code.
Having done so, this particular router (a spoke in a DMVPN network) is no longer able to negotiate DMVPN links with the hub. It appears that the GRE tunnel isn’t building.
Things in my log that are suspicious:
Mar 03 18:00:31 ms-fw1 opennhrp[4166]: [10.0.0.1] Peer up script failed: timeout
So this probably points the GRE/NHRP failure
Mar 03 17:58:18 ms-fw1 charon[3880]: 13[IKE] initiating IKE_SA dmvpn-NHRPVPN-tun1[2] to 192.168.200.1
And this is totally confusing because I’ve never used 192.168.200.1 for anything. It doesn’t show up in my config…So where is that coming from?? That appears to be hard-coded somewhere in a conf file on the system from the installation.
These are the two rolling releases that I’ve tried:
1: 1.3-rolling-202003031741 (default boot)
2: 1.3-rolling-202002290910-
Any thoughts?
