Ill start by saying im a sysadmin, not a network guy. So if there is something blatantly obvious, im sorry
Im currently trying to setup a network.
On one side i have one network provider giving me 2 ipsec tunnels with BGP running between them, they are advertising 10.10.16.0/23. I then have my vyos machine. Then i have 2 IPSEC tunnels with BGP running between them to connect the vyos machine to my AWS environment, the AWS side is advertising 10.10.0.0/20.
Im not even sure if this is a valid configuration to be honest.
All 3 tunnels are up and the routing table looks good, but i cant ping from one network onto the other.
[code]vyos@vyos:~$ sh ip bgp
BGP table version is 0, local router ID is 178.32.xxx.xxx
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
r RIB-failure, S Stale, R Removed
- 10.10.0.0/20 169.254.22.93 200 0 9059 i
*> 169.254.23.125 100 0 9059 i
*> 10.10.16.0/23 10.255.255.5 0 3209 3209 3209 3209 3211 64800 64800 64800 64800 64800 ? - 10.99.0.0/24 169.254.22.93 200 0 9059 i
*> 169.254.23.125 100 0 9059 i - 10.100.0.0/24 169.254.22.93 200 0 9059 i
*> 169.254.23.125 100 0 9059 i - 10.133.111.0/24 169.254.22.93 200 0 9059 i
*> 169.254.23.125 100 0 9059 i[/code]
[code]vyos@vyos:~$ sh ip route
K>* 0.0.0.0/0 via 176.31.xxx.xxx, eth0 (recursive is directly connected, eth0)
S 0.0.0.0/0 [1/0] via 176.31.117.254
B>* 10.10.0.0/20 [20/100] via 169.254.23.125, vti0, 02:51:02
B>* 10.10.16.0/23 [20/100] via 169.254.23.125, vti2, 00:30:33
B>* 10.99.0.0/24 [20/100] via 169.254.23.125, vti0, 02:51:02
B>* 10.100.0.0/24 [20/100] via 169.254.23.125, vti0, 02:51:02
B>* 10.133.111.0/24 [20/100] via 169.254.23.125, vti0, 02:51:02
C>* 10.255.255.4/30 is directly connected, vti2
C>* 169.254.22.92/30 is directly connected, vti1
C>* 169.254.23.124/30 is directly connected, vti0
K>* 176.31.xx.xx/32 is directly connected, eth0
C>* 178.32.xx.xx/32 is directly connected, eth0
[/code]
Heres my BGP config:
protocols {
bgp 65500 {
neighbor 10.255.255.5 {
password ****************
remote-as 3209
soft-reconfiguration {
inbound
timers {
holdtime 30
keepalive 10
weight 100
neighbor 169.254.22.93 {
remote-as 9059
inbound
timers {
holdtime 30
keepalive 10
neighbor 169.254.23.125 {
remote-as 9059
inbound
timers {
holdtime 30
keepalive 10
network 10.10.0.0/20 {
network 10.10.16.0/23 {
If i havnt provided enough info, please let me know.
Cheers!
