Shruti
1
I am using virtual box 5.1.20 and i am running VyOS machine on it.
Evertime i reboot VyOS VM, all configuration files/changes i have done are lost. Machine comes to initial state from where i started.
Does it happen with eveyone or do i need to do other settings so that changes are not lost on reboot.
You need to run
install image
after you boot from iso and login
I suspect you do changes on live system boot from iso
I am facing same issues even if i run install image.
so after committing your changes, you saved them right?
yes, i commited them, then save . Then i rebooted the system. When it comes up, all changes are lost.
Your router is not still booting from the livecd is it?
Shruti
7
How can i check if my router s booting or not booting from livecd ?
Incidentally, I had to upgrade to the nightly builds in order to get the configuration to persist across reboots.
1.1.7 has been working fine for me across several devices.
