We made a physical change to our network and now when our systems attempt to contact the outside world, the connection is sporadic. It seems like the router, or some router is stopping transfer shortly after a connection. I’ve included some basic wget on a linux system to illustrate what’s happeneing.
[root@storage ~]# wget http://mirrors.cat.pdx.edu/centos/6.7/updates/x86_64/repodata/2123a9b143f6c786498bdf05a65efbd678b0905a27f53c53223e71b42a3656d0-primary.sqlite.bz2
--2015-10-05 15:27:02-- http://mirrors.cat.pdx.edu/centos/6.7/updates/x86_64/repodata/2123a9b143f6c786498bdf05a65efbd678b0905a27f53c53223e71b42a3656d0-primary.sqlite.bz2
Resolving mirrors.cat.pdx.edu... 131.252.208.20, 2610:10:20:208::20
Connecting to mirrors.cat.pdx.edu|131.252.208.20|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 2010050 (1.9M) [text/plain]
Saving to: “2123a9b143f6c786498bdf05a65efbd678b0905a27f53c53223e71b42a3656d0-primary.sqlite.bz2”
2% [===> ] 59,368 38.8K/s in 17s
2015-10-05 15:27:27 (3.35 KB/s) - Connection closed at byte 59368. Retrying.
--2015-10-05 15:27:28-- (try: 2) http://mirrors.cat.pdx.edu/centos/6.7/updates/x86_64/repodata/2123a9b143f6c786498bdf05a65efbd678b0905a27f53c53223e71b42a3656d0-primary.sqlite.bz2
HTTP request sent, awaiting response... 206 Partial Content
Length: 2010050 (1.9M), 1950682 (1.9M) remaining [text/plain]
12% [++++===============> ] 249,056 --.-K/s eta 72m 23s ^C
As you can see the connection stops and wget retries. This type of behaviour is the same when trying to update via yum. I get so many bytes of the package before it just stops downloading, then yum assumes it lost connection because the mirror is down and tries another mirror. We get more byte, but ultimately on larger packages we either have to try to download many times, after it goes through each mirror.
I’m not sure where to begin looking at the vyos config to troubleshoot. I’m very green to the vyos myself. I have knowledge of network which is why I’m at a routing issue.
The layer 2 traffic goes perfect to and from virtual and physical hosts in the internal network. Any connections to external sources is where we’re having the issue.
Thanks to anyone with ideas.
