What is AES-NI?
OpenSSL 0.9.8 in VyOS 1.0 doesn’t support AES-NI. Intel provides a package called Intel Accelerator OpenSSL Engine [ direct download ]. This engine contains AES-NI support which can be used in OpenSSL 0.9.8 if your hardware is compatible. Intel has a list of processors that support AES-NI on their web site.
[quote=README]…This is essentially a collection of assembler modules from development OpenSSL branch, packed together as a standalone engine.
“Standalone” means that it can be compiled outside OpenSSL source tree without patching the latter. Idea is to provide a way to utilize new code in already released OpenSSL versions constrained by support and release policies limiting their evolvement to genuine bug fixes…[/quote]
To compile the source code, you need to install some packages. Add the debian repository in the configuration:
repository debian {
components main
distribution squeeze
url http://ftp.nl.debian.org/debian
Install the following packages:
(I’ve copy/paste this install command from Linux Mint - Community. I’m pretty sure the number of packages can be less. Please let me know which packages to remove.)
$ sudo apt-get update
$ sudo apt-get install build-essential automake autoconf libtool pkg-config libcurl4-openssl-dev intltool libxml2-dev libgtk2.0-dev libnotify-dev libglib2.0-dev libevent-dev checkinstall
Download and compile the source code:
$ wget https://www.openssl.org/contrib/intel-accel-1.5.tar.gz
$ tar -zxvf intel-accel-1.5.tar.gz
$ cd intel-accel-1.5
$ make
After compiling, the result is a file called [font=Courier]libintel-accel.so[/font].
Place this file in the openssl-engine directory:
$ sudo cp libintel-accel.so /usr/lib/ssl/engines/
You can use test this new setting by testing the openssl speed with/without the intel-accel engine:
$ openssl speed -evp aes-256-cbc #Without the intel-accel engine
The 'numbers' are in 1000s of bytes per second processed.
type 16 bytes 64 bytes 256 bytes 1024 bytes 8192 bytes
aes-256-cbc 72423.77k 118062.53k 133166.83k 137723.90k 139193.00k
$ openssl speed -evp aes-256-cbc -engine intel-accel #With the intel-accel engine
engine "intel-accel" set.
aes-256-cbc 289293.51k 334365.18k 339216.01k 339013.63k 339301.72k
If you do not wish to compile the source code or install the necessary packages. I’ve include an attachment containing the [font=Courier]libintel-accel.so[/font] file. Unpack the zip file and place it in the directory /usr/lib/ssl/engines and hopefully it works.
