OpenVPN configuration error: Failed to start OpenVPN tunnel.
#1
I have vyos1.7 with WAN bridge br0 and LAN eth4. I created the cert. I want to add openvpn but I got error.
set interfaces openvpn vtun0
set interfaces openvpn vtun0 mode server
set interfaces openvpn vtun0 hash sha512
set interfaces openvpn vtun0 encryption aes256
set interfaces openvpn vtun0 server subnet 10.0.8.0/16
set interfaces openvpn vtun0 server name-server ‘23.98.129.9’
set interfaces openvpn vtun0 server name-server ‘23.98.129.1’
set interfaces openvpn vtun0 openvpn-option “–proto udp”
set interfaces openvpn vtun0 openvpn-option “–keepalive 10 120”
set interfaces openvpn vtun0 openvpn-option “–port 1194”
set interfaces openvpn vtun0 openvpn-option “–dev vtun0”
set interfaces openvpn vtun0 openvpn-option “–client-to-client”
set interfaces openvpn vtun0 openvpn-option “–comp-lzo”
set interfaces openvpn vtun0 openvpn-option “–persist-key”
set interfaces openvpn vtun0 openvpn-option “–persist-tun”
set interfaces openvpn vtun0 tls cert-file /config/auth/fw20–server.crt
set interfaces openvpn vtun0 tls key-file /config/auth/fw20–server.key
set interfaces openvpn vtun0 tls ca-cert-file /config/auth/ca.crt
set interfaces openvpn vtun0 tls dh-file /config/auth/dh2048.pem
commit
[ interfaces openvpn vtun0 ]
[[interfaces openvpn vtun0]] failed
Commit failed
