I’m having some trouble with my openvpn setup. I can connect to it OK. But once connected, no traffic will pass whatsoever. I can’t even ping the remote side of the tunnel.
This is a brand new install with no firewalling setup whatsoever. I’m seeing the same behavior on two different clients, mac and linux. Both can connect OK, but pass no traffic at all once connected.
vyOS config;
vyos@vpn02:~$ show configuration
address 10.0.0.100/24
duplex auto
hw-id 00:0c:29:cf:9e:7e
smp_affinity auto
speed auto
loopback lo {
openvpn vtun0 {
encryption aes256
hash sha512
mode server
openvpn-option --comp-lzo
server {
domain-name home.domain.net
max-connections 5
name-server 10.0.0.12
push-route 10.0.0.0/24
subnet 10.99.1.0/27
tls {
ca-cert-file /config/auth/ca.crt
cert-file /config/auth/vpn02-server.crt
dh-file /config/auth/dh4096.pem
key-file /config/auth/vpn02-server.key
protocols {
static {
route 0.0.0.0/0 {
next-hop 10.0.0.1 {
distance 1
service {
dns {
forwarding {
cache-size 150
listen-on vtun0
ssh {
listen-address 10.0.0.100
port 22
system {
config-management {
commit-revisions 20
console {
device ttyS0 {
speed 9600
host-name vpn02
login {
user vyos {
authentication {
public-keys user@home.domain.net {
key ****************
type ssh-rsa
level admin
ntp {
server 0.pool.ntp.org {
server 1.pool.ntp.org {
server 2.pool.ntp.org {
package {
auto-sync 1
repository community {
components main
distribution helium
username ""
syslog {
global {
facility all {
level notice
facility protocols {
level debug
time-zone America/New_York
linux client config;
client
proto udp
cipher AES-256-CBC
auth SHA512
remote-cert-tls server
verb 4
dev tun
cert user.crt
key user.key
ca ca.crt
remote 10.0.0.100 1194
comp-lzo
Some info from the VYos device;
[code]vyos@vpn02:~$ show ip route
S>* 0.0.0.0/0 [1/0] via 10.0.0.1, eth0
C>* 10.0.0.0/24 is directly connected, eth0
C>* 10.99.1.0/27 is directly connected, vtun0
vyos@vpn02:~$ show version
Version: VyOS 1.1.7
Description: VyOS 1.1.7 (helium)
Copyright: 2016 VyOS maintainers and contributors
Built by: maintainers@vyos.net
Built on: Wed Feb 17 09:57:31 UTC 2016
Build ID: 1602170957-4459750
System type: x86 64-bit
Boot via: image
Hypervisor: VMware
HW model: VMware Virtual Platform
HW S/N: VMware-56 4d 70 26 2a ac d7 33-a3 42 f0 af a4 cf 9e 7e
HW UUID: 564D7026-2AAC-D733-A342-F0AFA4CF9E7E
Uptime: 13:13:49 up 1 day, 13:40, 2 users, load average: 0.00, 0.01, 0.05
[/code]
Is there something else that needs to be done/enabled on the vyOS system? I’m pretty sure it’s not a local network issue since I first set this same config up on a PFSense VM using the same IP and subnets (that VM is currently off) and that works fine.
I’m wondering if there’s some routing somewhere I missed or just have to enable.
Thanks!
