Given the example in the map above, how does the link between router R11 and R21 has to be configured so that communication between Host A and Host B always goes through router R12?
Only in case the link between router R12 and R21 goes down, the “backup” link between R11 and R21 should become the active routing path.
First , we should use the same area in all links , if we use different areas the internal-area prefix is preferable to inter-area. . So it could give problems when we want to manipulate the traffic.
if we are using the same area (1 or 0) we just need to change cost on the link that we want to be the primary, the traffic should go through to the selected primary path.
