Hello, I am another new user. I may have posted this earlier, but I didn’t see my post (sorry if there’s a duplicate)
I am having issues setting up OSPF between vyOS routers. Hopefully this is an easy one.
I am following the example for OSPF outlined in this guide. However, when I use the command “set interfaces loopback address 1.1.1.1/32” I get the error:
“Configuration path: interface loopback address [1.1.1.1/32] is not valid
Set failed”
I tried other addresses: (5.5.5.5/32, 127.5.5.5/32, 127.5.5.0/24…)
For some reason the current loopback lo address is 127.5.5.5/24. I tried even tried that using the command to designate that address and I still received the same error.
Is there something I should be considering?
Any help appreciated, thank you.
