anyone else having problems with ospfv3 crashing?
if I run show ipv6 ospfv3 neighbor it will be blank.
tried
sudo /etc/init.d/vyatta-quagga restart ospf6d
doesn’t seem to help, it then just says OSPFv3 is not running
seem to have the problem on version 1.0.4, 1.1.1 and 1.1.2
any ideas?
just to quickly add to this, the only thing which maybe slightly different to a standard config is that we are using two areas
show protocols ospfv3
area 0.0.0.0 {
interface eth1
range ::/0 {
advertise
range fc00:41c8:10:1dd::/64 {
area 1.1.1.1 {
interface eth6
range ::/0 {
advertise
range fc00:41c8:11:1dd::/64 {
parameters {
router-id 10.1.6.2
redistribute {
connected {
route-map connected-to-ospf6
kernel {
route-map static-to-ospf6
static {
