I have ebgp connection to a peer. However, when I check show ip bgp neighbor 195.66.228.254 and show configuration commands | match 195.66.228.254 they do not present the same info. I deleted the import route-map, but it seems to be still in use. Below are outputs of both commands:
csadmin@edge2-cvdc:~$ sh conf commands | match 195.66.228.254
set protocols bgp 59455 neighbor 195.66.228.254 description ‘LINX-WALES-Route-Collector’
set protocols bgp 59455 neighbor 195.66.228.254 ‘nexthop-self’
set protocols bgp 59455 neighbor 195.66.228.254 remote-as ‘5459’
set protocols bgp 59455 neighbor 195.66.228.254 route-map export 'OUT-LINX-WALES-v4’
set protocols bgp 59455 neighbor 195.66.228.254 timers holdtime ‘90’
set protocols bgp 59455 neighbor 195.66.228.254 timers keepalive ‘30’
csadmin@edge2-cvdc:~$ sh ip bgp neighbors 195.66.228.254
BGP neighbor is 195.66.228.254, remote AS 5459, local AS 59455, external link
BGP version 4, remote router ID 195.66.228.254
BGP state = Established, up for 2d18h05m
Last read 14:32:46, hold time is 90, keepalive interval is 30 seconds
Configured hold time is 90, keepalive interval is 30 seconds
Neighbor capabilities:
4 Byte AS: advertised and received
Route refresh: advertised and received(new)
Address family IPv4 Unicast: advertised and received
Graceful Restart Capabilty: received
Remote Restart timer is 120 seconds
Address families by peer:
IPv4 Unicast(not preserved)
Graceful restart informations:
End-of-RIB send: IPv4 Unicast
End-of-RIB received: IPv4 Unicast
Message statistics:
Inq depth is 0
Outq depth is 0
Sent Rcvd
Opens: 16 1
Notifications: 0 0
Updates: 6 1
Keepalives: 7903 8962
Route Refresh: 0 0
Capability: 0 0
Total: 7925 8964
Minimum time between advertisement runs is 30 seconds
For address family: IPv4 Unicast
Inbound soft reconfiguration allowed
NEXT_HOP is always this router
Community attribute sent to this neighbor(both)
Inbound path policy configured
Outbound path policy configured
*Route map for incoming advertisements is IN-LINX-WALES-v4
*Route map for outgoing advertisements is OUT-LINX-WALES-v4
0 accepted prefixes
Connections established 1; dropped 0
Last reset never
Local host: 195.66.228.245, Local port: 33042
Foreign host: 195.66.228.254, Foreign port: 179
Nexthop: 195.66.228.245
Nexthop global: 2001:7f8:4:4::e83f:9
Nexthop local: fe80::212:c0ff:fe4c:6d47
BGP connection: non shared network
Read thread: on Write thread: off
Please let me know why this is happening.
Thank you
Petr
